Chester Conquest Super Mill
Home Forums Introduce Yourself – New members start here! Chester Conquest Super Mill
  • #729306
    pvm
      @pvm
      Old new member. My interests are Myford ml7 lathes, Chester mini mill machine, chop saw, walker turner press drill
      band saw, arc welder etc
      I am retired and has you probably have guest my hobby is engineering  My member  name is  PVM
      pvm
        @pvm
        Hi all
        My  “Chester Conquest Super Mill”  has been a brilliant bench top mill. Over the years I have put some very heavy work through it,  However the motor has developed a problem ,Having checked fuse, power supply, and motor brushes All ok .On start-up motor will run,  Then any adjustment to speed motor stops and wont start again until a number of hours pass . I deduce that my problem is the potentiometer ,My request is where is the best place to buy one and what is the correct specification for it. The existing one has the following makings “B4K7” I have looked on the Chester web site but only get no items to come up.
        Regards  PVM
        #729316
        Bazyle
          @bazyle
          The B4k7 means it is 4700 ohms. or 4.7k ohms. This is an extremely common value for potentiometers, really really standard part. Just find one on ebay that looks the same size.
          Google “4k7 potentiometer”.
          #729463
          pvm
            @pvm
            Thank you bazyle  for your reply to my query re potentiometer  regards PVM
