I had some vinegar-salt solution that had been used successfully to clean some lightly-rusted steel. Having used vinegar to clean brass, in the past, I dropped some brass into this used solution. The brass cleaned up reasonably well, but areas of copper-colour spoiled the finish. I suppose this was due to ‘de-zincification’: am I correct? What is a good way to chemically clean brass without this risk?
Then I thought I’d clean some slightly rusted steel shimstock, in the same, contaminated solution. It instantly became copper-plated. Oh, like steel in copper sulphate solution, I thought to myself. Then I suppose my aged brain shut down, because I tried to remove the Cu with fresh acid. Silly! It just instantly re-plated – as any thinking person would expect (sigh). Light abrasion got rid of it. But the question remains: how would you chemically remove Cu deposits from steel/iron? Are there Cu-specific chelators, for example? I suppose I could have increased the volume of acid wash. Any better ideas?
