I had been using a marble chopping board as a surface plate, I think it may have come from Dunhelm Mills. Placing an engineers straight edge over both sides I was able to get a ten thou feeler under the middle on the concave side and on the opposite convex side it was similarly distorted. In truth it was bent. While being probably OK for marking out on non critical machining jobs, it was unreliable for measuring say with a vernier height gauge. and slip gauges with grinding in mind.
Next step, I have a glazier friend and he kindly cut and dressed a piece of laminated glass
30 x 35cm x 12mm thick. I expected much more accuracy with this but although it is a great improvement and will probably be ok for general machining it would still not be good enough for precision measurements.
Just a suggestion, a large thick piece of say, half inch thick good quality gauge plate would probably afford a better degree of flatness but the cost might be creeping toward a new, small commercial surface plate.
After all that, I have discoverd, a bit late in the day that the heavy duty length of kitchen worktop I use for a bench is flatter than the marble and the glass over a similar surface area – funny old world init?
Stuart
