Cheap ‘Radiator Keys’
Home Forums Hints And Tips for model engineers Cheap ‘Radiator Keys’
  • #529218
      On the off-chance that people may find another use for them:
      Radiator Keys for 1/4” square are available from HomeBargains at 79p for two.
      They are remarkably similar to these: **LINK**
      https://www.castironradiatorcentre.co.uk/products.asp?code=CDC-BLEEDKEY&name=radiator-bleed-key
      Not a very convincing ‘square’ compared to some alternatives, but that may make them even more adaptable.
      https://storelocator.homebargains.co.uk/
      Edited By Michael Gilligan on 21/02/2021 20:16:12
        Paul Lousick
          @paullousick59116
          You could make your own by forging one.
          Making a square intermal shape can be done by drilling a hole in a piece of round bar that just slides over the corners of the spindle on the valve. Then heat the round bar (red hot), insert a piece if square rod with the same size as the spindle and squash it down onto the square rod. Remove the square rod while still hot or it may not come out.
          #529238
            dont know
            That’s why I remarked upon the price.
            Steviegtr
              @steviegtr
              I have a few good quality brass ones on key rings. I did buy a cheap couple for the tool box only to find they were a bit oversized & slipped on well used & bled rads.
              Steve
              #529242
                In case it’s not obvious …
                I was proposing them as “make from” material, not as radiator keys.
                Edited By Michael Gilligan on 21/02/2021 21:44:28
                #529245
                Steviegtr
                  @steviegtr
                  Posted by Michael Gilligan on 21/02/2021 21:43:13:
                  yes
                  Steve.
