I only have a large propane bottle so didn't fancy carrying it around to use my Sievert stuff, The "big middle sized one". It doesn't need refilling very often. I bought my torches from Cousins – all in cheapest at the time and they have always offered a good service.
It used to be possible to get a simple screw on torch for the 400 odd gm bottles. Maybe nearly a 1" dia nozzle that puts out a fairly gentle flame for it's size and didn't flare. I'm in no rush and some plumbers used them. They would cause a yorkshire fitting to melt in one go, no running a pencil flame round them which is what they seem to do these days with some risk of burning the solder due too much heat,
I went for this one due to amazon reviews on other makes. If it holds up as the name seems to suggest they are a bit of a bargain. Often it's cheaper to buy off amazon these days but the reviews are useful anyway.
The ability to run on MAP's might be useful for some other things. Seems to burn 25% hotter than propane.
I bought a bottle of that too from Toolstation – not sure what I will use it for
other than quick hardening in the kitchen.
Edited By Ajohnw on 01/12/2016 19:18:59
