There is a brand called Measuremax who use a form of serial interface between the calipers or scales and a small display unit. They sell a lead that fits the tiny plug on the scale unit and has a USB plug on the other end. It likes to fall out. However, I don’t think it is USB electrically, I don’t think you can just plug it into a PC and run a program to use the PC as a display…which is a pity as that would be a cool idea. They do sell a small unit that does the display as a separate item. I have one of these, it is supposed to run from a phone style rechargeble battery. The battery for mine died, I am trying to come up with a way of running from the mains, but so far have been getting interference type problems, the wires are evidently picking up noise and I haven’t been able to find a way to eliminate it. (eg making sure the scale is insulated from the machine itself.)
If all this sounds like damning with faint praise, you are on the right track…everything including the scales was much cheaper than the top line stuff, and the accuracy is fine…if I just use the scales everything is great, except that I have to bend around awkwardly to read the scales themselves. The little display would be nice, if I could just set it up to run from the mains. Since they don’t always get turned off, battery operated things have a habit of being flat just when you need them.
The code used for the signals from the scale to the display are documented in some of the measuremax stuff that can be found online. Of course other brands with similar connections may not use the same code.
regards
