Thanks to all for replies.
Posted by SillyOldDuffer on 23/09/2023 17:21:05
I'm surprised ChatGPT didn't suggest EDEN as the answer to Amundsen's forwarding address. Amundsen disappeared in 1928 on a rescue mission, suggesting God called Amundsen home because He loved him too much. In comparison to a clear case of divine intervention is it likely a Norwegian knew 'mush' was the 'go forward' command given in Canada to Huskies? I don't believe Amundsen ever said 'mush', or that his hounds knew what it meant…
Well yes! My reason for presenting this challenge to ChatGPT was that it needs some very 'human' reasoning to solve. I'd be surprised if anyone solved the clue 'cold' when it appeared. I certainly didn't – I needed crossing letters, say _U_H.
Because the thing about Amundsen using dogs on the South pole expedition was closer to the surface of my mind than his disappearance and there is an association (albeit incorrect) between Huskies and "mush" (I gather it's Hike! nowadays) in my mind, I solved the clue and knew that was the answer. That certainty was the result of a complicated web of associations which inter alia involved 'that's just the sort of dirty trick Bunthorne would pull'.
To give ChatGPT a better chance I gave crossing letters. Me and ChatGPT:
Can you solve a crossword clue for me?
Of course, I'd be happy to help you solve a crossword clue! Please provide me with the clue, and if you have any letters that are already filled in, let me know those as well.
The clue is: Amundsen's forwarding address? (4) It conforms to the pattern ?U?H
rose-invert light”>
The answer to the crossword clue "Amundsen's forwarding address? (4)" with the pattern ?U?H is "SOUTH." Roald Amundsen was a famous Norwegian explorer who is known for being the first person to reach the South Pole, hence the reference to "SOUTH" as his forwarding address in this crossword clue.
[perhaps I should have given a proper regex? But we now have an assertion of the 'correct' answer.]
The solution must have four letters as indicated by (4) in the clue. Can you try again?
I apologize for the oversight. Given the pattern ?U?H and the requirement for a four-letter word, the correct answer to the crossword clue "Amundsen's forwarding address?" is "RUSH."
['Correct' is now explicit. I answer using the same word.]
Thank you. The correct answer is "MUSH". Can you explain how the clue works?
rose-invert light”>
Certainly! The clue "Amundsen's forwarding address?" with the pattern ?U?H is a clever play on words.
- "Amundsen" refers to Roald Amundsen, a Norwegian explorer known for his expedition to the South Pole.
- "Forwarding address" suggests that you should think about where Amundsen was heading or moving toward during his famous expedition.
- The pattern ?U?H hints at a four-letter word where the second letter is "U," and the last letter is "H."
Putting these clues together, you get the word "MUSH." In the context of Roald Amundsen's expedition to the South Pole, "mush" refers to the command used to urge sled dogs to move forward. So, it's a clever way of linking Amundsen's journey to the word "mush" as a forwarding command for his sled dogs.
[That's pretty impressive! We got there in the end.]
That is the correct explanation. I have no further questions at present.
I'm glad I could help explain the crossword clue to you! If you ever have more questions or need assistance in the future, feel free to reach out. Happy crossword solving!
Good God. I hardly know what to say. That's creepy.
Robin
