Hello Jason,
Regarding my flash steam engine the high rpm are required to develop the HP.
The engine is a very simple design with uniflow ports to let the exhaust out and a poppet valve operated by a cam to let steam in (car exhaust valve machined down to size).
There is a weight limit on this hydroplane 16lbs dry so it is very difficult to be a legal weight for competition.
Gearing is unnecessary due to weight and power loss the service piercing propeller has to rotate fast to be efficient, it is a prop rider only one blade in the water when at speed.
The water is carried on board, as any contamination will stop the pumps.
The HP is debatable and there are various formulae but I only no the Time it takes to do a certain Speed over 500metres, a rough guess comparing IC engines to mine might be around 6bhp at 10,500rpm?
The IC glow plug engines rpm is higher than mine.
Turbines are allowed but weight again raises its head and I am in the process of finishing one as an exercise.
On my photo album there is my steam generator testing nozzles for the turbine.
But you need a great amount of steam to be as fast as my piston engine.
Steam generated by chemicals would do as some of the small fuel pump turbines fitted to one of our past rockets developed vast amounts of HP.
Paul
Edited By Windy on 13/02/2013 12:55:15
Edited By Windy on 13/02/2013 13:00:44
