Posted by John C on 18/09/2020 11:05:46:
I use F360 as a personal, not for profit user. The 'free ride' is most definitely not over. I spoke to F360 support who pointed me to this blog Fusion 360 Blog which explains exactly what is happening. I was concerned about the reference to 10 documents, but the link above explains that this refers to 10 active documents; when you reach the limit of 10, simply archive an active document – make it inactive – and you are able to work on another document. All documents remain saved as archive documents, always accessible.
I looked at Fusion when I wanted to draw something in 3D that I couldn't (easily) do with TurboCAD D/L or Open SCAD (both of which I still use btw). Fusion 360 was clearly very popular and had one BIG advantage, in that it included a CAM element. However, I deeply disliked (& indeed distrusted) the Cloud based nature of Fusion, so was very pleased to find that Solid Edge 2020 (free Community Edition) was not cloud based and (I'm not sure why) it also seemed to suit me better – I hadn't really enjoyed trying to learn F360.
So I don't know very much about F360. My 3D CAD knowledge is limited to Open SCAD and SE 2020. However, in the later, I design 'parts' (each being a separate file) which then are joined together into 'assemblies' (another file). If I need a 2D drawing, then this is again a new file.
This is very unlike the way I worked in TurboCAD – where I tended to have one large 'model' with parts defined and separated by either page geography and/or multiple layers. I've not made any very complex SE 2020 designs thus far but I can see that if I was limited to just ten "active" parts, that it might be an issue. I don't know if I'm understanding this correctly in F360 terms though.
As an aside, the lack of CAM in SE 2020 did slightly worry me – but in fact I've not made the jump to CNC as yet – and may never do so. 3D Print is another story of course. However, I have noted with interest the increasing use of commercial "printing" sources by other Gauge '3' colleagues. There was a very interesting 3D 'Printed' part shown recently (made with a metal sintering process) that would have required lost-wax casting or some similarly complex to produce not so long ago. Members are also using outside sources to get parts printed in more 'exotic' materials that are not so easy to use at home. So I'll worry about CAM when I have the actual need.
Anyway – Solid Edge 2020 Community Edition seems very capable of meeting my current needs and everything runs locally, still a very big bonus to my mind.
IanT
