Hi all,
I recently started trying to cut threads on my Warco WM250V lathe, but I have encountered a problem. I was trying to cut a 1.25 pitch thread, but after assembling the change gears to suit, the thread which was cut was far too fine. After checking with a thread gauge, it appeared to be 0.6. I then double checked the gears and they seemed to be correct, a 30, an 80, a 75, and a 60 tooth, with the gear selector in the A position. I then moved the gear selector to the B position and cut a thread, which seemed to be very slightly finer than a 1.25 pitch. My thread gauge doesn't measure 1.2 pitch, but I suspect that is what it was. I then moved the gear selector to the C position and tried to cut a thread. What I got could hardly be called a thread, but it was definitely very fine, much finer than the 0.6 earlier. Looking at the gear chart on the lathe (I have attached a photo) the results I'm getting would indicate I have a 60, a 50, a 30, and an 80 tooth gear train, but I definitely don't. What's confusing me is that I've done the calculations as best as I can, and from what I can tell, the gear train I have fitted should have given me a 1.25 pitch originally.
Can anyone shed any light on what I'm missing here?
(FYI the number of teeth on the spindle gear is 40, and the lead screw is 2.0 thread pitch if you want to double check my calculations)
