Posted by
Andrew Johnston on 17/09/2010
I hate centre drills! You’ve only got to look at the smaller ones and the centre bit goes ping.
Hi Andrew,
I’m inclined to agree with you, having on a (very) few occasions had to dig out the tip of a centre drill from a workpiece. However, over the past 60 years of my engineering career both practical and academic, I have either been too blind or too stubborn to notice the alternatives. I have to admit to never having `discovered’ spot drills until quite recently, thanks to you kind people who have tugged at my reins with your postings.
Like me, when you know no better, you become quite skilled at getting the best results from a particular piece of equipment. For me, centre drills have burned their place into my brain, and thus became my automatic choice. Considering the amount and range of specialised equipment I have built over the years, it now seems quite remarkable how I’ve managed to get away with using nothing else for locating a `marked-out’ hole position.
Getting the most out of a piece of equipment has reminded me of working on the apprentice’s lathe back in the early 50’s. Driven from a 10HP electric motor via an overhead counter-shaft (running the length of the shop), the lathe had a three-step pulley and when it was running, it had about 5 yards of flat belt flying past your left ear.
It was a cow of a machine!
My main tasks were turning ejector pins for plastics moulds, and much larger aluminium shrink-pins (used for controlling the diameter of hard rubber textile bobbins during their steam curing process). Applying more than a ten thou cut, the long thin ejector pins were likely to leap over the tool bit, and the tail-stock never seemed to stay on centre no matter how many times it was re-adjusted.
Changing speeds was also a skill in itself. Aided by a five foot long `spare’ wooden lever which was slightly notched at one end, the out-of-reach (overhead) end of the flat belt had to be jabbed from below to flick it from one pulley step to the next. Then, down at lathe level, the belt was give a swift slap with a flat hand to get it to jump onto the lathe pulley. I suspect that the entire workshop (even the factory) would be closed down under current `work-practices’ regulations.
As you can imagine, I learned quite a bit about the maintenance of flat-belt drives, especially when one broke or the coupling clasp or pin wore through. By the way, via the counter-shaft, the 10HP motor also drove a horizontal power saw, a surface grinder, and another lathe larger than the apprentice’s machine. There were times when the surface grinder would slow down if we were all simultaneously drawing torque from the system. I suspect that the main drive belt from the motor (about a four inch wide flat leather affair) was slipping.
Another use for the 10HP motor, since it made a fair bit of noise, was as a `Start Work’ signal first thing in the morning, after morning tea-break, and also after lunch.
In closing, does anyone know the name of the steel which we referred to as BND? This was a tough steel which was later hardened, tempered, and then ground to size.
Happy centring.
Sam
