""David George 1:
This was the pipework just below the pump. The two pipes were the fill and expansion pipes and the elbow was about a foot below the pump. Apparently thus is the place where blockages happen if anywhere.""
That is absolutely appalling, Dave. The "plumber" who did that, (or rather didn't – flush the system), should be shot !
I found a similar horror when I dismantled a combi boiler that wasn't working very well; valves half blocked up with swarf from "plumbers" who couldn't be bothered to do a proper job. Lazy sodding bastards – I bet they charged the full whack.
Fit a Fernox TF 1 "Total" magnetic cyclone filter while you have the system drained. Just under £100 from Screwfix and a good bit of kit. You won't be disappointed. Look at the guarantees with new boilers: 7-10 years if fitted with a filter, 5-7 years if not.
Like SoD, I set our heating to come on twice a day, and I leave it up to the house and hot water thermostats to decide whether to fire up the boiler or not. Our house thermostat is set between 13-15 degrees. It is a mindset – turn up the heating or put on a sweater.
Being forced semi-retired, and not being larks, we don't need to get up early anymore, so I have set the heating not to come on until 1000, by which time the house has usually warmed up anyway. No point wasting gas heating the house when we are still warm in bed !
Edited By John Doe 2 on 07/11/2022 16:58:49
