Hi All,
We have been in our house now 20 years and love living here in lovely Dorset.
House was built 1988 by a local, now long defunct, company who were total; t*****s and left us a litany of problems as the second owner, most of which I was able to fix. A lot younger then of course!
One such problem was that one day we noticed a musty smell in our utility room and on lifting the lino floor covering there wwas a damp spot in the concrete floor. After careful excavation and a lot of swearing i got down to the offending copper pipe to be greeted by the finest mist like spray possible.
Cause: the idiots had laid the 15mm copper straight into the wet concrete floor with no hessian or protective covering whatsoever. It was REALLY difficult to find enough room to get some slack and cut out the bad section as it was close to a wall. Finally bodged a fix with some speedfit and flexible pipe. Not ideal but solved the problem.
All nice and rosy for the next 15 years…… UNTIL a week ago!! Got up to be greeted by the War Office saying there was no hot water. OK, out to the garage and sure enought the combi boiler (new 3 years ago) is showing a pressure of 0.2 Bar, below the cutoff at 0.4. Opened the filler valves to pressure back up to 1.4 Bar and all works OK.
Next day the same performance, after repressurising and using the system during the day all seems OK unless we go out for a few hours when same problem again on our return. Checked and bled all the rads, no air in the system. Goes down overnight every night now.
Got a heating engineer in today who thought it would be the PRV sticking but on breaking the union there was no sign at all of any water in the pipe so that is not the cause. He then puts on a doleful face and says I have a leak in the system! I CAN ONLY GUESS WHERE FROM.
The whole downstairs is the original concrete floor with new carpet in living room, very expensive solid oak in hall and dining room, ceramic tiles to kitchen /utility/
How on earth do I go about finding this leak which I am sure will be very small? When I find it what is the best way forward as I guess it will just happen again somewhere else?
When i 'fixed ' the first leak I was paranoid that I might have disturbed the pipe a couple of feet away under the concrete and caused anothe pinhole.
Any thoughts gratefully received, I can not begin to tell how depressing this is.
How do I stand with my insurance for which I have got plumbing cover?
Cheers,
Martin
