Posted by John McCulla on 09/04/2023 23:09:20:
Hi all,
I have a cut section of 60mm round bar in which I want to tap an M24x3 thread. I drilled and bored it out to 21mm, and then attempted to tap it in the lathe, using the tailstock with a centre to keep the tap straight, however it was requiring too much force…
[Move to drill press]
Or is there a better way?
First, moving the job to a drill-press is a legitimate technique. It allows more force to be applied, but is likely to create a new problem – how to hold it!
Exactly as Ady and others have said, I use the lathe to remove most of the metal in threads of above 10mm or so, and then use a tap or die to finish off. The lathe produces an accurate straight pitch and does all the hard work without busting a gut. Then the tap (or die) runs straight down the partial thread and cleans and forms it to the correct profile. The combination plays to the strength of both tools and avoids their weakesses. As found, tapping an M24x3 thread is hard work, with a risk of breaking the tap, skewing off, and chewing the thread.
Another common trick is reduce the amount of work the tap or die has to do by widening the hole or slimming the rod. Boring out to 21mm for M24 means the tap has to remove enough metal for a 75% engagement. 70% engagement is more usual in soft materials, and 50% in steel. About 65% on average. Home-workshops can go even lower. Opening the bore to 21.5mm would roughly halve the torque needed to tap an M24 thread.
Apart from Brass and Cast-Iron, it's essential to lubricate when threading. Proprietary cutting fluids are best, I've always used CT90 because my local emporium sells it! Paraffin is OK for Aluminium and engine oil helps everything else.
Tapping horizontally in a lathe, or vertically in a blind hole, tends to choke the tap with swarf, so withdraw the tap and clear the hole every so often. Also, manually driven taps and dies should be reversed a half turn after every other full turn. This breaks any swarf ribbons that are forming – the break can be felt giving with a sort of click – and helps swarf drop clear of the cutting edges. (Mincing swarf is hard work and blunts the cutter!)
