Centec milling machine NT30 chuck.
Home Forums Workshop Tools and Tooling Centec milling machine NT30 chuck.
  • #657603
    Michael Callaghan
      @michaelcallaghan68621
      Hi, my centec milling machine uses NT30 chucks, however I can’t find a slitting saw arbour this fitment. Can anyone point me in the right direction to purchase one. Thanks.
      Michael Callaghan
        #657609
        Saxalby
          @saxalby
          I had the same problem needing one for my Tom Senior horizontal spindle (Int30). I already had a Clarkson Autolock chuck so turned up a couple of adapters to take the various slitting saws I had.
          Regards Barry
          #657658
          DC31k
            @dc31k
            Why do you need a special arbor for slitting saws? Do they not fit on the standard horizontal arbor? Or is it for use with the vertical head?
            This might be a good place to start:
            https://www.rdgtools.co.uk/acatalog/30-INTERNATIONAL-TO-1–FACE-MILL-ARBOUR-1040.html
            It has a 1" spigot, that will suit many slitting saws. It has a key in it whch can be adapted or discarded. Remove and discard the drive dogs. All you need to make is a cap and some spacers (or buy the spacers or borrow them off the horizontal arbor).
            You could buy a plain shank slitting saw arbor and mount it in a 30 taper ER32 collet chuck. Lots more bang for your buck that way. You can similarly make a 'plug in' full horizontal arbor to suit the ER32 chuck.
            #657659
            Speedy Builder5
              @speedybuilder5
              3 Ba is 4.0894mm diameter x 34.8 tpi or 0.73mm pitch
              #657660
              Dave Halford
                @davehalford22513
                I have gently used the horizontal arbor in the vertical head angel
                #657671
                Michael Callaghan
                  Dc31k, it would just make the job a lot easier using the vertical head.
                  #657680
                  DC31k
                    @dc31k
                    Rotagrip list one. The link is incomprehensible, so search for:
                    'slitting saw arbor 30 int rotagrip'
                    #657685
                    Anonymous
                      Posted by Michael Callaghan on 23/08/2023 17:57:30:
                      …it would just make the job a lot easier using the vertical head.
                      In my experience a slitting saw on an arbor unsupported at the outer end will go walkies if the depth of cut in more than a few millimetres. On the other hand using a horizontal arbor, supported at the outer end, one can go as deep as the saw will allow with no tendency to wander.
                      #657707
                      Howard Lewis
                        @howardlewis46836
                        If you are using a Slitting Saw, do NOT use a key.
                        If anything jams, the saw is likely to split and surround you with flying metal.
                        Luckily, I was not quite alongside when an Apprentice using a key (Disobeying instructions ) had his saw split. Half of the saw was still rotating on the arbor as the other pieces fell all around, and came down from the roof!
                        #657720
                        Michael Callaghan
                          Thanks Howard. Good point made, and I will be sure to make use of your suggestion.
