Centec 2A riser block
Home Forums General Questions Centec 2A riser block
Viewing 7 posts - 26 through 32 (of 32 total)
  • #424272
    Gary Wooding
      @garywooding25363
      NDIY:
      I made several batches of RBs. The 1st batch had the Centec logo machined into the side and hi-lighted with black paint, as shown in the first 3 photos. The subsequent batches had the brass labels shown in the last photo, but I fitted them only on the 1st of them. For the remainder, I supplied the badge and hammer-nails with instructions on how to fit them, but left the actual fitting to the buyer. You possibly have one of those. I fitted stainless dome nuts and thick machined washers to all my blocks, so if yours has them then it could be one of mine.
      The 457mm length was as I ordered, but I had to clean them up and possibly lost a mm.
      not done it yet
        @notdoneityet
        Posted by Gary Wooding on 15/08/2019 07:26:29:
        Gary,
        I know – hence the smiley! I think there was a centec badge in the boxes of bits that I got with my machine. No complaints from me on the quality. It makes a very good machine even more useful. I’m delighted with it.
        #508403
        Jason Copland
          @jasoncopland51808
          Good Morning All,
          resurrecting an older thread here with a long shot question – has anyone made an adapter riser block to enable a MKIII vertical head to be mounted onto an Automil MKII?
          (I'm after plans if anyone has anything, long shot I know but if not then I'll have to make it from scratch)
          Cheers
          Jason
          #508422
          Dave Halford
            @davehalford22513
            Beware of tolerances, I have both a 2 and a 2A, a dovetail made a good fit for the 2A is too big for the 2. The Centec made horizontal arm and Mk2 vertical fit both. Centec made an adapter for the C/Automill a very rare item.
            #508431
            Jason Copland
              @jasoncopland51808
              Posted by Dave Halford on 19/11/2020 11:41:25:
              Thanks Dave.
              I had heard of tolerances varying slightly. I had a 2b Universal which I've now sold but retained the vertical head.
              I had heard tell of the Centec made adapter but I suspect I have next to zero chance of finding one and I'm not bothering to look much – did a quick search around on various places but nothing hence my intention to make one. Apart from the retaining blocks it looks to be a fairly straight-forward operation. The Automil is a far beefier machine than the 2b but seems to be rather rare nowadays. I've never seen another.
              #508455
              Dave Halford
                @davehalford22513
                When you cut the slot for the inside dovetails drill through and counter bore top and bottom for some hold down bolts.
                There have been a couple of machines on Ebay.
                Edited By Dave Halford on 19/11/2020 13:56:50
                #718485
                Henry Bainbridge
                  @henrybainbridge40560
                  If anyone is interested in making a short riser, there are some perfect billets on sale on Ebay right now: https://www.ebay.co.uk/itm/145611920138
                  I just bought one as they are 75mm wide, and 208mm deep (perfect size) and are already squared off nicely, with holes pre-drilled in the sides to hold down on the table, so that saves me a lot of work. Almost made for the job, and cheaper! There are 7 more units left.
                  PM me for seller’s email.
