The Minimag should be fine.
I generally set my engines to spark a few degrees before TDC on both pushrod operated valves as well as the atmospheric ones on the hit and miss engines.
What level is your fuel tank? For initial testing I tend to use a plastic tank and flexible hose so I can play about with the best position, should not be such an issue on your throttle governed engine but on the hit & miss engines there is a risk of fuel draining back between hits.
Have you tried choking the carb, a finger part covering it or even a bit of tape will do.
