CENTAUR GAS ENGINE
CENTAUR GAS ENGINE
Home Forums I/C Engines CENTAUR GAS ENGINE
  • #2618
    Pete Berry
      @peteberry
      Pete Berry
        @peteberry
        I have recently completed building a CENTAUR ENGINE. It starts and runs well but it does jump about quite a bit.Not sure if the balance would be improved if I used an aluminium piston instead of the cast iron one. I would be interested to hear how other people's engine perform?
        #555792
        kevin laxon
          @kevinlaxon28008
          A friend has made several hit & miss open crank barn engine's,we have found the one's that jump about as a rule of thumb don't have the couterweights on the inside of the flywheel rim 180° from the crank pin,some also have the flywheel lightened inline with the crank pin,I know of the centaur but have had no dealings with one,hopefully others will know more.
          #555816
          MichaelR
            @michaelr
            I built a Centaur and fitted a aluminium piston but not for the purpose of reducing rough running but for my own liking, I don't think a cast iron piston will contribute to rough running.
            Video of my engine running just sitting on a non slip mat. engine now has a new owner.
            Edited By MichaelR on 26/07/2021 16:01:56
            #555853
            Pete Berry
              @peteberry
              Thanks Kevin I will give it a try.
              #555855
              Pete Berry
                @peteberry
                Hi Michael your engine certainly runs smoother than mine , I have some ballist in the base but I still have to hold in down. I think I will try an ally piston.
                #555856
                Former Member
                  @formermember12892
                  #556374
                  Pete Berry
                    @peteberry
                    Problem solved. I balanced the crankshaft as per E Westbury,s instructions in his book "Model petrol engines" I had to increase the size of the balance weight which now have a radius of 3 inches. The engine now runs much smoother without jumping around. smiley
                    #556378
                    MichaelR
                      @michaelr
                      Pleased to hear you have solved your engine problem and with not a great deal of extra work.
                      Michael
                    Home Forums I/C Engines Topics
