Centaur build
Centaur build
Home Forums I/C Engines Centaur build
  • #2523
    AJW
      @ajw
      AJW
        @ajw
        Pressing on with my set of castings for Centaur.
        Today saw machining start on the flywheel, cuts well but as with some of the others I have machined they could have been a bit more generous with the material!
        [url=https://postimg.cc/0b298PZp][img]https://i.postimg.cc/0b298PZp/Flywheel-inner-face-and-bore.jpg[/img][/url]
        All finished one side and reamed the bore so need to remount to complete the other side.
        I have made a slight change to the original design by increasing main and big end running diameters to 5/8 which looks a lot 'meatier'
        Anyone interested can have a look in my photos to see what I've been up to!
        Alan
        Edit- sorry, photo didn't happen!
        Edited By AJW on 02/11/2018 20:38:46
        Edited By JasonB on 02/11/2018 20:47:53
        #381696
        Pete Berry
          @peteberry
          Looks good so far. I have just finish mine and have had it running on propane and petrol. I found that the carb spring needed to be a little stronger than the write up suggested!
          Pete Berry
          #381747
          AJW
            @ajw
            Pete, nowhere near the carb build but thanks for the heads up!
            Enjoying the journey so far – yours run ok?
            Alan
            #381842
            Pete Berry
              @peteberry
              Hi Alan
              Yes mine runs well and starts easy, I'm using coil ignition. Just a tip fit a non return valve in the fuel line (just a simple ball returning by gravity). I'm having a problem up loading photos but hope to in future.
              Pete
            Home Forums I/C Engines Topics
