Centaur big end lubrication
Home Forums I/C Engines Centaur big end lubrication
Viewing 2 posts - 1 through 2 (of 2 total)
  • #555443
    AJW
      @ajw
      I built my engine a couple of years ago (photos in my album) and it never got totally finished. So with renewed enthusiasm I'm on a mission!
      One point I was never happy with was the banjo arrangement for lubrication of the big end bearing. This is designed to recycle the oil lost from a main bearing and carry it to the big end.
      I have therefore dismantled the big end bearing and am in the process of fitting a lubricator screw top pot to hold oil. This will have a feed hole directly to the bearing and rather than start off with a hole that's too big I have drilled it 0.45mm on the non load side.
      Obviously it's very small but is it the sort of size I should be aiming for? I tend to use a 5-30 synthetic oil on all engine parts.
      Alan
      AJW
        @ajw
      Home Forums I/C Engines Topics
