CE mark for boilers
CE mark for boilers
Home Forums Beginners questions CE mark for boilers
  • #49770
    Speedy Builder5
      @speedybuilder5
      I am planning to make the boiler for a 5inch Speedy loco. How does not having a CE mark affect the running of such a boiler ? and are there known plans to make non CE marked boilers (or any other part) un insurable etc ?
      Speedy Builder5
        @speedybuilder5
        #49772
          Its only commercially made boilers after 2002 that need CE marking. So provided you can show it was made by you there should be no problems.
          Jason
          #49777
          DMB
            @dmb
            I had a Sweet Pea boiler made commercially some years ago and still not steamed it or got it steam tested as I still havn`t finished the rest of it. Needless to say,  there is no CE mark on it.
            How do I stand  with current test requirements? Can anyone please advise?
            KWIL
              @kwil
              You do not have a problem. As it was made before the CE mark came into play it is not required to be marked. Marking is not retrospective. Just have it hydraulically tested, then steam tested by your local club inspector as normal when you want to put it to use.
