Hi
While I do have the beginnings of cataracts they are not "ready" according to my opthomoligist. I do wear glasses for long sightedness, from age 50 I needed them. Now I need glasses for all distances. I wear them nearly all the time.
I switched to continuous varifocals a few years ago. The standard type are heavy. Thinner lighter types are available at higher cost the refractive index of the is different making them thinner and lighter. The benefit is my nose can cope with the weight better, as your prescription changes and if your glasses are getting thicker worth looking into.
Yes the days of levelling work by eye are gone…. varifocals put paid to that, there is too much distortion. You get used to the distortion within a week or two, the human brain is a wonderful thing it adjusts to them. I would never switch back to separate reading and distance glasses.
As you can see from my photo I prefer aviator style glasses with wire frames, better protection and a wider field of view. They also tend to stay on when I am looking down into a piece of machinery, they don't fall off. They are sturdy. I also look for big softish nose pads for wearing comfort and request they be fitted no charge when I order a new pair.
My worst experience with glasses was when a pair was fitted too high.
When you order your glasses they will ask you to look into a device that looks a bit like a pair of binoculars or alternatively they will put the glasses style you are ordering on and mark the dummy plain glass lenses that are fitted to the shop samples with a felt pen. What they are actually doing is measuring your eye height relative to your nose and the lens.
They got the measurement wrong; they did not fit properly, now I pay particular attention when they take the measurement. Ideally you want an experienced specialist fitter.
For something you wear 16 hours a day it is important to get it right.
The same applies for the eye test, repeat each step until you are sure that A or B is better, don't let them hurry you.
Edited By John McNamara on 01/12/2016 11:09:49
