It just depends on where you are starting from, there is nothing wrong in making things in steel or any other bar stock, but this can be quite time consuming and produce lots of swarf!
On the other hand castings give a basic shape that just needs the relavant surfaces machining, with less waste.
Buying “commercial” castings gives you the time saved in machining away the waste you would have had if you machined from solid, but you pay for an element of the pattern making costs plus transport costs.
If you are fortunate enough to have a local foundry then making your own patterns will pay dividends especially for mutiple items as the costs are a lot more reasonable.
Edited By Chris B on 29/01/2010 22:31:27
