This morning I have received a sample set of castings from Blackgates Engineering, for my model 'Norden' the 18th century mill engine which is currently being serialised in ME.
I have only been able to give them a quick look over:
The castings are the base, flywheel, two pulleys, cylinder, cylinder end cap, steamchest and steamchest cover. They are also including a 'Tich' eccentric casting which is suitable for the model.
The fine spoke cross sections are vulnerable to flash but this should be easy enough to remedy with multi-tool as I did on the original. I can't see how this could be avoided without resort to much more expensive lost-wax casting.
It looks like the price will be very reasonable, perhaps a good choice for someone who has been put off by the cost of castings for some larger models.
Please contact Blackgates direct if you are interested in a set. I plan to do some trial machining in the near future.
