Casting the wheels for “Onward”.
Home Forums Traction engines Casting the wheels for “Onward”.
  • #308712
    Maurice Cox 1
      @mauricecox1
      I have just watched a video of the casting of the rear wheels for the replica traction engine "Onward". It is very interesting, but there was just music on the sound track. I could follow most of it except when it came to pouring the iron. First, a small crucible was used to pour a small quantity of iron into the mould, about the volume of two house bricks, then a much larger crucible was used to pour enough to completely fill the mould. Can anyone tell me what the reason for this was please, and is there a version of the video with a comentary?
      Maurice Cox 1
        @mauricecox1
        Explanation of a video..
        #308721
        Brian Oldford
          @brianoldford70365
          Did the second pour empty the crucible?
          #308740
          Maurice Cox 1
            @mauricecox1
            It appeared to, yes.
            #308744
            Jeff Dayman
              @jeffdayman43397
              The first bit of iron may have been used to warm the runner system and burn off any water or flammable gases that may have been in the mould, while the runners and fill system were mostly open to atmosphere. If such gases or steam were present while the main pour was being done, filling the runners, an explosion of the mould might result. I've seen this "first pour" done on big steel pours (about 5 tons of steel) at a foundry I did a co-op term in many years ago. The shop men called it "wetting its' whistle". JD
              #308747
                Could well be right Jeff as it looks like it was poured into the vent gate and did not look like it was done to make up for not enough capacity of the in the main tilting crucible.
                I did have a look on Traction Talk at the thread when the video was first posted but could not see it mentioned.
                J
                #308938
                Maurice Cox 1
                  @mauricecox1
                  Thanks for that gents. I did think that, as they were casting the iron round the cold ends of the spokes, it may be some sort of preheating from the radiant heat. It is a pity that there is no commentary.
                  #308945
                  Ady1
                    @ady1
                    Cheap pre-heating? Resulting in a better casting
                  Home Forums Traction engines Topics
