casting rubber / urethane parts
Home Forums General Questions casting rubber / urethane parts
  • #689809
    Derek cottiss
      @derekcottiss41883
      I have a project which involves the need for a cast ‘rubber component ‘
      i have no knowledge (other than u tube ) of whats really involved  any pointers please ?
      anyone near Essex do this sort of thing ?
      Robin Dufton
        @robindufton85682
        What does the part look like and what is it for? I designed and built tools for a rubber moulding company so can likely answer any questions on that front.
        Youtube should be able to tell you all you need to know for the basics.
        #689928
        DC31k
          @dc31k
          ISBN-13 ‏ : ‎ 978-0830698691
          #689936
          Ian Parkin
            @ianparkin39383
            Afew years ago i had a job to repair a pallet wrapping station which had a u section steel section bent into a large circle about 5ft dia on the floor ….into the section was a hard rubber which after 20 years was starting to deteriate so when the bearings holding the 7 ft dia disc floor were running on this rubber track it was vibrating like mad. particullary when a 1 tonne pallet was being wrapped
            i chiselled all the old rubber compound out and filled it with a 2 part Polycraft DuroFlex 85 Polyurethane Liquid Casting Rubber which i got from MB fibreglass
            it cured a treat and after 3 years now of daily use its still perfect
            a new part from the maker was in excess of 2k so my £60 of rubber did an excellent repair
            MB do allsorts of compounds
            #690334
            Derek cottiss
              @derekcottiss41883
              The object to cast is a rifle butt pad and a cheek piece actually batches of 10 for a target chassis system we make  ..
              #690337
              Derek cottiss
                @derekcottiss41883
                yes been looking at them and waiting for some samples
                #693992
                nigel jones 5
                  @nigeljones5
                  you could 3d print them in TPU quite easily – low outlay
                  #694825
                  Derek cottiss
                    @derekcottiss41883
                    except the price of the printer of course
