Casting concrete beams
Home Forums General Questions Casting concrete beams
  • #21747
    John Lawson
      @johnlawson61116
      John Lawson
        @johnlawson61116
        Does anyone have any experience of casting steel reinforced concrete beams, we wish to replace the wood beams on our raised track with something more stable and would welcome any guidance as regards mix, casting etc.
        Thanks
        Peter Tucker
          @petertucker86088
          Hi John,
          What size are your beams and what loading are they going to have?
          Peter.
          #58008
          bricky
            @bricky
            Hello John.
            The size of the beam and the length is a factor.
            If you have access to a machine to lift the beams then they can be cast in shuttering on the ground.If not they will need to be cast in situ in a supported shutter.
            The mix for concrete for beams (shovels)10 gravel 5 Sharp sand 2 cement or if it is mixed ballast I use 7 ballast 1 cement.
            The reinforcing bar needs 2 longitudal rods top and bottom with bar bent into a square at 300mm centres tied with wire to the 4 rods to form a cage.Keep the cage 25mm up from the bottom/side&top .Hire a vibrating poker to remove the air .Hope this helps
            Francis
            #58011
            Nicholas Farr
              @nicholasfarr14254
              Hi John, Francis mix seems a little weak to me. The info I have gives a general purpose mix of ballest otherwise knowen as pre-mix of 4 to 1, however if it is out in the weather it would want to be a paving/driveway mix of 3.5 to 1. I have not got any info on a structual beam, but I would think it would have to be at least as strong as a driveway.
              Regards Nick.
              #58015
                @brian
                Sounds like a lot of hard graft to me.
                This link http://www.mexboroconcrete.com/brochures/ebeamsbrochure1.pdf may solve the weight and construction time problem for the straight section of trackway.
                This would leave the curved section to be cast insitu, but it could cut out a lot of back breaking work.
                Just a thought.
                Regards Brian
                No connection with this company, Honest.
                #58051
                John Lawson
                  @johnlawson61116
                  Hi Paul
                  As the beams are a direct replacement for the existing raised track they are 1.8mtr long 200mm wide and we proposed to make them fishbellied shape from 100mm at the ends to 200mm in the centre with 2 lengths of rebar in the bottom section.
                  As for loading ? how many fat people can you get on the 1.4mtr free span.
                  We will cast these on site and lift them in so we can keep the track available for use we have about 100 to produce.
                  Edited By John Lawson 1 on 03/11/2010 10:49:55
                  #58054
                  DMB
                    @dmb
                    Do you have to have concrete beams? Many tracks have A shaped support pillars topped by all sorts of beams including wood. Worthing Model Engineers use 2 channel steel sections laid on sides with the `bottom` of the channels back to back. I dont know how the beams were bent. The passenger car bogies (cast ali. – frem) have an outboard steel drop – arm bolted on with a right – angled stubby bar which travels inside the channel, but not normally touching it. This arrangement serves as a very effective anti – tip device. I am anformed that the track was not originally planned in this way and that  a member responsible for devising the anti – tip thought up this simple brilliant solution.
                    Solving the channel bending prob. would make a simple system for other tracks without recourse to many additional bars and tubes of steel added on under the track with the increased difficulty in grass cutting under the track.
                    Just a thought but hope it helps someone.
                    John.
                    #58055
                    DMB
                      @dmb
                      Sorry, can spell! Previous post said “cast ali. frem” but this was meant to be “frame”,
                      #58073
                      Jeff Dayman
                        @jeffdayman43397
                        Just FYI For the strongest possible concrete I have found a mix as below works best:
                        3 parts crushed 3/4″ stone
                        2 parts sharp sand
                        1 part cement
                        Use minimum possible water. If you can get some chemical plasticizer and air entrainer it will increase workability while using less water.
                        Good luck. JD
