Posted by Samsaranda on 20/07/2019 13:51:16:
Digressing briefly away from the subject of the thread, I have always wondered if perhaps cast iron would be a suitable material for the crankshafts in small ic engines, I mean those of only small capacities say up to 7 – 10 cc. I feel that it would be much easier to machine than steel but I am curious as to whether it would survive the stresses in the engine?
Dave W
Cast-iron is strong in compression but relatively weak in tension, and it's also rather brittle. I think the alternating stresses in a crank-shaft would soon break it. Before steel I believe crank-shafts and other reciprocating parts were made of Wrought Iron for the same reason. Does anyone know what Stephenson used?
Several 19th century cast-iron bridges failed, perhaps most famously the Tay Bridge, which tragedy led to North British Railway Engine No 224 being nicknamed 'The Diver'.
The most common cause of collapse of these structures seems to have been failure of cast-iron members under tension, though quality problems like blowholes featured too. At best not a good material when bending and pulling are involved.
