I made a 6 3/4" backplate out of a piece of meehanite which started at about 200mm. There was a hard bit on part of the OD about 1/4" deep, just like an interrupted cut. I was glad to get through it, and doubly glad to have a variety of TNMG16 inserts. I drilled and tapped the CI to fit on a faceplate and did the od and face so it would fit in a four jaw for the rest of the turning. The mess was incredible, despite having magnets set to catch the cast iron dust.
If I ever have to do something like that again, I will try to get a piece of SG iron.
I bought a 160mm ci blank from a well known supplier for a 160mm chuck and it was under size. It would have cleaned up at 152mm, but I left a bit uncut at 155mm. I contacted the supplier, who immediately refunded my money and said keep it. I reckoned that the three 8mm rear mount screws would be too near to the edge for comfort, so I simply drilled and tapped for six 6mm screws to hold the chuck instead, they could be on a slightly smaller pcd as well as being smaller diameter.
Edited By old mart on 04/07/2019 23:15:37
