Hi Kristian,
A plain unhardened mild steel cylinder will last a very long time in a model, if you include a displacement lubricator in the steam line for oiling the inside and you paint the outside to keep rust down. A brass or phosphor bronze piston will work great in a mild steel bore (or a cast iron bore). Don’t bother case hardening a mild steel cylinder, there’s really no need, unless you plan to run the model every day for ten years.
A cast iron cylinder will also work very well, especially if you can get a small piece of ‘meehanite’ grade cast iron stick, it will turn and mill beautifully and run a very long time, as long if not longer than mild steel. Most full size steam engines had cast iron cylinders so it’s likely not an accident !
Brass will work as a cylinder too, but its’ life depends on what kind of brass it is. Soft brass may wear kind of quickly. Bronze is great too, but usually a bit expensive.
If you need plans for a displacement lubricator try one of the “simple steam” books by Tubal Cain. All kinds of good advice in there.
By the way, stay away from aluminum for any parts that are exposed to steam (or that need inertia, like flywheels). Some grades of aluminum corrode and wear rapidly in steam depending on the grade.
Good luck with your project.
JD
Edited By Jeff Dayman on 05/12/2011 19:19:36
