Peter- what exactly are you making that warrants EN32 or equivalent.
Yes, it will case harden deeper quicker, yes its a slightly better material than mild without becoming interesting/exotic, but first you have to carburise, then you have to refine at specific temeperatures.
To gain a small improvement in core strength, you are it seems to me getting into production controls to get the best out of a material which won’t be any harder in the case at the end of it all. About the only difference is that the case will be a bit deeper quicker, (useful for industry where they often grind case hardened surfaces) which for a one off(?) is not normally a great problem.
Do you need a 31 ton(f) tensile substrate after heat treatment?
West Yorkshire Steels BTW.
