Posted by Steviegtr on 04/01/2020 17:51:13:
I am sure we used to use Potash to case harden.
'Potash' is another of those names used loosely by various trades for different chemicals: any of several minerals containing Potassium, Potassium Oxide, Potassium Hydroxide and Potassium Carbonate. Only the Carbonate would be any good for case hardening. I doubt it was used on it's own, more likely a mixture containing Potassium Ferrocyanide and – perhaps – Potassium Cyanide.
Case Hardening is done in a multitude of different ways, sometimes just to provide a hard wearing surface, other times to produce a decorative hard-wearing surface (pretty colour for jewellery and guns), or – in the good old days – armour plate for battleships!
I guess this thread is about improving the wear resistance of mild-steel by carburising a thin surface layer. This can be done with almost any source of carbon, but it's hard to control results. Kasenit, Cherry-Red and other commercial mixes are formulated to simplify their use in an ordinary workshop. Follow the instructions and there's a good chance a semi-skilled user will get a reasonable hardened layer from simple equipment! It won't be very deep, nor is the process particularly cheap. I suspect (but don't know for sure) that all these product also harden by Nitriding as well. Kasenit seems to have been withdrawn because it contained Potassium Cyanide; deadly if misused. Ferrocyanides are safe.
Alternatively case-hardening can be done by baking mild-steel in charcoal, or by playing a Carbon Rich Acetylene flame over metal heated to just the right temperature. But I don't think the method is easy or reliable. Adding Leather or bone-meal introduces Nitrogen, which I think improves the chance of getting a good result, but it's not consistent. No-one knows how much Nitrogen will be in a particular bit of old leather, so the worker has to judge by eye and smell. Plunging red-hot mild-steel into used engine oil is said to work, but I doubt the results are trustworthy. But there's no reason why an amateur method like that shouldn't produce some improvement. Why not try it?
The grown-ups go for expensive to set-up but cheap to run and methods. They strongly favour reliable results, same hardness and colour every time! Controlled heating in an atmosphere of Butane, Propane, Carbon Monoxide, Ammonia or Acetytene or a mixture of same is good for many mass-production items. When colour and/or deeper skins are needed, steel can be soaked in molten mixtures of Barium, Sodium and Potassium Carbonates, Ferrocyanides, Cyanides, Charcoal and other chemicals. As accidentally mixing air with hydrocarbons is likely to cause an explosion, and because the fumes from these processes may be toxic, it's likely the work will be carried out in a vacuum furnace. The details depend much on the particular steel being hardened and the purpose: decorative gun parts are unlikely to be hardened in the same way as a crank-shaft.
If the goal is a vague desire to improve the wear resistance of ordinary mild-steel I don't see much harm in trying traditional recipes. As an amateur though, when looks or performance matter, I'd cough up and buy a commercial mix. Deliberately developing skills in traditional methods is also worthwhile if that's your interest and you have the time needed to learn the ropes.
Edited By SillyOldDuffer on 04/01/2020 19:36:41
