case for eight day clock
Home Forums Work In Progress and completed items case for eight day clock
  • #31054
    roy entwistle
      @royentwistle24699
      roy entwistle
        @royentwistle24699
        Adrian I am very pleased to see your article re building a long clock case in the latest Model Engineer Could I ask you for a materials list of the timber used
        As a further comment I realise that the case has been dimentioned using CAD
        but isn't 5.6875" and 0.5625" a little bit ambitious in wood ?
        Roy
        #154952
        Bazyle
          @bazyle
          Not for JS.wink See the drill grinding jig thread for his experience in a piano making factory.
          #154955
            Posted by roy entwistle on 10/06/2014 09:01:17:
            Not if you have a ruler calibrated in sixteenths
            Bob Brown 1
              @bobbrown1
              And good eyesight or a big magnifying glass
              #154963
                Get within 1/4" and in weather like the past week it will spend some time exactly on size
                roy entwistle
                  @royentwistle24699
                  It might be a mental thing but I can work with 0.0625 in metal I can probably work with 1/16th in wood but to my mind 0.0625 is exact whereas 1/16 is about right
                  Roy ( I'm bringing tolerances up again aren't I ? )
                  #154995
                  julian atkins
                    @julianatkins58923
                    roy,
                    i hope you never make a set of dovetail joints with 1/16" tolerance! wont be much of a decent joint!
                    cheers,
                    julian
