You need good alround stiffness and setup, this stops them blunting/chipping
You need to grind a slight concave just behind the tip
(use a green grit wheel for carbide)
You need to grind a tiny amount of clearance from the tip to the base of the tool, giving it internal strength because it's almost vertical
Give it a slight rounding, sharp pointy tips are too weak, but keep the top flat, so it goes straight into the concave depression
The bottom line is:
Practice practice and…. practice
In the case of carbide tooling, it's well worth the effort
This is an oval concrete reinforcing bar done with a single resharpening
Loads of intermittent cutting and only just fitting into the lathe centres
I have a set of carbide tipped lathe tools like these:
etc
edit:
Sometimes negative rake is better for cast iron, worth bearing in mind if you get a tough job
(It's pretty weird to see how well it cuts if you do run into this situation)
Edited By Ady1 on 06/02/2013 23:57:09
