I second ,or is that third, the recommendation of Sumitomo tips.
I personally prefer triangular tips as I am such a meanie, three edges over two useful ones!
Kwil, in this case you are slightly misinformed about small tips “thread producing” tips, unless of course you are using “roughing” feed speeds, as opposed to “fine finishing” ones. The very small tip radii are only meant for very fine finishing (at small feed rates) at which they excel.
The beauty of small radius tips, on our size lathes, is that they require very little effort to cut metal. This free-cutting shows itself in a lack of work piece and/or tool deflection, resulting in a better and more consistent surface finish. As I am sure most of us would agree that only a good “smooth” surface can be measured, with any hope of accuracy, and this finish can be easily achieved with Sumitomo small radius tips.
For those unfamiliar with the tips in question, they are not Tungsten Carbide but Titanium Carbide, which Sumitomo call “Cermet” (Ceramic+Metal).
Unlike many tips which work marvellously at industrial speeds and feeds, these tips can work at very small depths of cut, which is very useful for cutting that “last few thou” to get the size we want.
If there is a trouble with Sumitomo products, it is that that they keep changing the chip breaker designations. For any tip they might make three different chip breakers, not to mention tip radius, just as you get to remember which one you want, they bring out a new catalogue with new designations.The chip breaker is very important on these tips, as it denotes the depth of cut at which they work best. Having said that, I am sure that Carters will supply the right ones for “our” needs.
To sum up, if you have tried Carbide tips and wondered why people bother with them because of the lousy finish they can give on small lathes, try Sumitomo they will be a revelation.
chriStephens
Oh, by the way , I would not be without my Tangential tool, but there are times when even very easy sharpening, is out classed by no sharpening!
