I take a very experimental approach to machining, ~
a surf of the web when i was starting out indicated hobby machines lacked the rigidity & speed for carbide end mills.
Thought i'd give it a go anyway.
Seems there must be a demand in the hobby market as they're available from the usual suppliers?
My philosophy on end mills,( whilst i still had some free cash
) was basically to buy whatever was going cheap, of either a known brand or from a trusted supplier.
Largely the diameter of the end mill is not that critical for general purposes unless you are slot drilling?
Anyway i ended up with a number of fairly esoteric carbides, for not much money really. Brst time to buy machines or tooling is always yesterday.
Tried a few test cuts, Seem to work at least as well as hsco ~ better in terms of a finish pass IMO.
Then i put them away & returned to hss/ hsco until such times as i really needed to use them.
Anyone use carbide EM's regularly?
Does it last on a hobby mill? Or are we looking at a quickly worn/chipped tool?
Just wondering if i'd be better selling on, or hanging on to till the need arises.
Have you found them of benefit in a hobby mill?
What if any are the issues?
