Carb for single cylinder engine
Home Forums I/C Engines Carb for single cylinder engine
Viewing 25 posts - 1 through 25 (of 48 total)
  • #530674
    John Rutzen
      @johnrutzen76569
      My engine for the Rumely oil pull tractor I am building uses a scaled up version of E T Westbury's road roller design. The carb is also a scaled up version of that one. The air is controlled by a spring loaded slide which has no damper on it and it just bangs up and down as the engine runs. I notice that a similar design carb of his for his 1831 engine has a damper incorporated in the air slide. Has anyone any experience of these carbs and can suggest a mod to make it more controllable please?
      John Rutzen
        @johnrutzen76569
        #530679
        Howard Lewis
          @howardlewis46836
          Could you add a damper like that b used on the SU carb. Just a close fitting piston inside an oil filled bore.
          It should provide a more constant air:fuel ratio so that the engine runs more steadily, but may need to be set up slightly differently from the undamped version.
          May even run over a wider speed range, if that is needed.
          #530724
          John Rutzen
            @johnrutzen76569
            Hi Howard, yes that's what I'm thinking of trying, I'll get back to let you know if it works.
            #530728
            Andy_G
              @andy_g
              Could it be that the spring is too soft? (i.e. the air sleeve is massively over-shooting the desired setting, causing oscillation). If I read the original article correctly, it suggests a spring of 12 to 20 turns 1/2" OD 32SWG which I've calculated as 0.008-0.014 lbs/inch. If the design has been scaled up, the starting point would be these stiffness values multiplied by the square of the scaling factor. (Simply scaling the spring diameter up will result in a softer spring).
              I would expect a damper would undoubtedly help though.
              Edited By Andy_G on 28/02/2021 13:43:44
              #530729
              noel shelley
                @noelshelley55608
                I would go along with howards idea of something using the SU damping arrangement. Noel.
                #530751
                Tim Stevens
                  @timstevens64731
                  There is (was) a tendency in the motorcycle world to prefer plain Amal-type slide carbs for singles, but (sometimes) to use an SU carb (or a CV type) for a multi. The erratic suction of the single causes flutter of the suction-operated slide of the SU, so it is never in the intended position, whereas the continuous suction of the multi tends to make the Amal-type slide stick as it is continuously pushed sideways in its bore.
                  If the engine has a heavy flywheel, and gentle valve timing, so it is not snappy when opened up, you might find an SU with thick oil in the damper will be OK, though. Of course, this is the last sort of characteristic needed by the average motor bicyclist.
                  And incidentally, the SU damper was not 'just a close fitting piston … etc' The outer edge of the piston fitted accurately in the outer sleeve, and within the inner steel sleeve was a brass piston held loosely on its rod, with a valve in the base of the piston so that resistance in one direction was greater than the other.
                  Hope this helps
                  Tim
                  #530761
                  Howard Lewis
                    @howardlewis46836
                    Quite right Tim!
                    The extra damping in the upward direction of the slide provided mixture enrichment for acceleration, and unlike the rubber diaphragm in the Stromberg CV, the slide did not have a spring rate to add to that of the spring above.
                    The other advantage of the SU was that it was impossible to fit incorrectly oriented.
                    An AA man messed up my father's Viva HB by fitting the slide so that the two vacuum ports were on opposite sides of the jet bridge!. The car went much better when the slide and diaphragm were fitted in the right place!.
                    #530795
                    Roger B
                      @rogerb61624
                      I have been running an 5.5mm bore SU type carb on a 12cc twin. The piston doesn't have a damper but is fairly stable:
                      John Rutzen
                        @johnrutzen76569
                        I made a damper to fit inside the sleeve today using a piece of 1/4 inch brass tube and it has improved matters. I think getting the spring right will take quite a bit of experimenting.
                        #530974
                        Tim Stevens
                          @timstevens64731
                          A hint: Early (preWWII) SU carbs did not rely on springs to assist in returning the needle and piston assembly. Instead, the weight of the piston was altered (in development) so different models of car got different weights. This was often a steel washer rivetted on top of the piston flange. The main effect of changing weight or spring is response to snap throttle openings – too light and you got hesitation, too heavy and you got sluggishness. But perhaps with a tractor the need to snap the throttle open is reduced?
                          So, rather than finding lots of spring wire and diameters etc, it might be quicker to use a selection of washers on top of your carb piston. Much quicker to change and modify. And once you find something that works, it can (if necessary) be soldered etc in position.
                          Cheers, Tim
                          #530975
                          John Rutzen
                            @johnrutzen76569
                            I've found that the engine will only run very rich. To get it to start I have to inject a small amount of neat petrol into the intake and the exhaust is visible. If I try to lean it out it stops. The air slide is pretty much shut, if I open it the engine stops. I've tried messing about with the ignition timing and find it runs best if the spark is at about TDC or just after. It will run continually but only with the air slide shut. This is the first IC engine I've made, I've been a steam loco man up to now.
                            #530976
                            John Rutzen
                              @johnrutzen76569
                              Thanks Tim, I didn't see your post. I could try that but at the moment it doesn't like the slide open at all!
                              #530978
                              Roger B
                                @rogerb61624
                                Have you checked the valve timing? The exhaust should open towards the end of the firing stroke and close just after the next top dead centre. The inlet should open slighly before the exhaust closes and close as the compression stroke is starting. If you are out a tooth or so you can get pressure rather than vacuum in the inlet pipe which rather upsets things.
                                #530982
                                not done it yet
                                  @notdoneityet
                                  I don’t know the actual size of the original, nor 1.4 times it, but I suspect that the venturi effect is insufficient to draw and atomise the fuel (from the jet) at low speed
                                  #530987
                                  Howard Lewis
                                    @howardlewis46836
                                    If the steady state mixture is correct, but opening the throttle causes stalling, the slide needs to be damped in some way so that the increased air flow enriches the mixture while the engine accelerates, and then lifts the slide.
                                    As NDIY says, the air velocity over the jet bridge is insufficient to atomise the fuel.
                                    The float level should be set so that the fuel is only JUST below the jet bridge.
                                    As a guide, a previous post says that a 5.5 mm bore carb ran a two cylinder 12 cc engine. (Only one cylinder breathes at a time, so think 6 cc single cylinder! )l
                                    Howard.
                                    #530996
                                    John Rutzen
                                      @johnrutzen76569
                                      Hi, there is no float so the fuel level is over 2 inches below the jet bridge but that is the same on the road roller design. I don't know if the road roller runs satisfactorily as designed, there have been only a few made and I can't find any report on running it. To have a float would require a fuel pump. Could it be that the spark is weak? I have Jan Ridders ignition system which only runs on a 1.5 volt battery. I have ordered a 'proper' ignition system.
                                      #531004
                                      Roger B
                                        @rogerb61624
                                        IIRC this engine is around 35cc If you are looking at slow speed running a 5 or 6mm venturi will be fine. For power you might need something like 8mm but that will depend on the valve sizes and cam timing.
                                        #531006
                                        Howard Lewis
                                          @howardlewis46836
                                          Asking the carburettor to lift fuel two inches is asking a lot! No small wonder that there are problems atomising the fuel!
                                          That explains why starting is difficult, and it stalls when the throttle is opened.
                                          You are requiring the air flow and venturi to produce a depression of 2 inches of petrol. Full scale engines don't do that, which is why carburettors have a float chamber to keep the fuel at the right level in the jet.
                                          No need for a fuel pump if you can arrange a gravity feed?
                                          If you are departing from prototype by using a constant vacuum carburettor, you may as well carry on and fit a float chamber.
                                          You need to bring the fuel level upto that of the jet bridge, by some means..
                                          Before worrying about the ignition, since the engine runs at steady speed, with the present one, you need to put the carburation in order first.
                                          There would need to be a weak spark, marginally so, to cause the stall when the throttle is opened, if the mixture supply was correct..
                                          #531008
                                          John Rutzen
                                            @johnrutzen76569
                                            I think you are right about the fuel lifting, I think it's a bad design. The prototype doesn't allow for a gravity feed tank. I don't mind having a float chamber but from what i've read they can be tricky to get working.
                                            #531019
                                            Andy_G
                                              @andy_g
                                              Just double-checking that this is the design being discussed:
                                              http://www.modelenginenews.org/etw/roller/page52.html
                                              To correct my spring numbers above – It's 1/4" OD, so the relevant stiffness figures are 0.07 – 0.12 lb/in
                                              (If the scale factor is 1.4, I think the spring wire should be about 0.015" dia ).
                                              Posted by John Rutzen on 01/03/2021 14:46:23:
                                              Have you run it long enough for it to warm up? (Not unusual to have to lean out the mixture considerably over the first minute, or so.)
                                              What happens if you open the throttle? (I presume you mean the spring loaded sleeve when you say 'air slide ' ) – Apologies if I have got the wrong end of the stick.
                                              Edit to remove random smiley – have just seen latest info.
                                              What size of primary choke are you using? (The hole in the side of the carb)
                                              If the primary choke is too big, or there isn't a good seal between the air sleeve and its cylinder, the carb won't develop enough vacuum to draw the fuel through. Might be worth trying with a bit less than 2" height difference.
                                              Edited By Andy_G on 01/03/2021 18:17:54
                                              #531024
                                                I've made a couple of IC open crank engines that will easily lift fuel 2" but they do need a non return valve so that the fuel does not drain back on the miss stroke, you may get away without it on a throttler but worth adding anyway. The faster running Stuart Lightweight will also lift a small amount of fuel out of the bottom of the float chamber which is at least 2" lower than the venturi and that does nor have a NRV.
                                                Best thing to do is set the engine up with a temporary tank and flexi fuel line then you can see what effect raising and lowering the tank will give.
                                                You might also want to turn up a quick restrictor to put into the carb to reduce the venturi dia being a slowish reving engine you won't want as big an area as a performance engine
                                                #531030
                                                Tom Sheppard
                                                  @tomsheppard60052
                                                  Have you considered replacing the carburettor with a simple spraybar as used in a model aircraft engine in order to establish a calibration datum? This would help you to get the engine running nicely before spending a lot of time going down a series of trial and error blind alleys to find a solution.
                                                  #531031
                                                  Roger B
                                                    @rogerb61624
                                                    Another show and tell wink This is my 25mm bore 50mm stroke engine running with a 4.3 mm bore model aircraft type barrel carb. I could get a higher output with a bigger carb but it was more 'touchy' The tank is around 30 mm below the carb.
                                                    John Rutzen
                                                      @johnrutzen76569
                                                      Thanks to everyone who has replied, I think the simplest idea would be to put a non return valve in the line. Would this be an ordinary steam type clack valve with a ball? I'll also follow up on the suggestion to attach the tank with a flexible pipe and try adjusting the level. The one in your video Roger runs a lot more smoothly than mine does. Mine runs more like a 'hit and miss'.
                                                    Home Forums I/C Engines Topics
