car wiring loom
car wiring loom
Home Forums The Tea Room car wiring loom
  • #635941
    duncan webster 1
      @duncanwebster1
      The cabling which goes from the main body to the door on my car has started to give way due to repeated flexing. It has over 20 cores just to control the window, central locking and mirror. Model railways would achieve this with 2 cores via the Direct Cab Control. Even if you don't want to send control signals down the power line I would guess that 4 cores would be enough. Are car manufacturers still in the stone age?
      duncan webster 1
        @duncanwebster1
        #635943
        Dave Halford
          @davehalford22513
          That's why they invented CANbus
          #635949
          noel shelley
            @noelshelley55608
            Whilst dave is right it is often easier to fix a broken wire rather than a computerised system. Noel.
            #635991
            Dave Halford
              @davehalford22513
              Posted by noel shelley on 03/03/2023 15:56:23:
              Exactly
              #636006
                Posted by duncan webster on 03/03/2023 15:22:24:
                No, [see Dave Halford’s post]
                Having sorted that, years ago, they’re busy now … designing silly toys, as per my BMW thread
                duncan webster 1
                  @duncanwebster1
                  I've had computers since the BBC (over 40 years?) and computer driven engine management systems for many years. The only problems I've had with any of them have been mechanical, broken wires, hard disc bearings etc. Further research on interweb shows that door wiring loom failure is a common fault on my model of car, fortunately I've tracked down a pattern part at 1/4 the cost of the manufacturer's. The break is too close to the plug to permit a crimp repair. Now wait for the weather to warm up a bit before I fit it, fiddly jobs outside when your fingers are freezing cold is not my idea of fun
                  #636044
                    In this cold weather … it might be worth staying indoors and having a look at this:
                    https://www.csselectronics.com/pages/can-bus-simple-intro-tutorial
                    Clever … and getting cleverer
                    Hopper
                      @hopper
                      If the cabling to your door is giving way, how old is your car? Maybe it is from the Stone Age. In tech world that is about five years, as I just found out when trying to get my phone repaired after the on/off button got sticky.
                      #636065
                      noel shelley
                        @noelshelley55608
                        Having read Michaels link I;m glad I have broken wires ! I understand them and with simple equipment can find and fix faults. Whilst I may be a dinosaur, I hope I'm not a Luddite. Having seen £250,000 macine stand idle for 6 weeks because it was so clever that the experts and technicians could not understand what was wrong, I'll stick with the old tech ! Agriculture and plant have yet to solve simple problems like rat and mice proof wiring, 1 wire and it's crippled ! Once started an old diesel needs no electrics ! Noel.
                        #636074
                        Phil P
                          @philp
                          I had the same problem with the drivers door loom on my Skoda Yeti, apparently they had originally made them a tad short and they failed near the hinge post. I could not even lock the car when it failed.
                          I was staggered at how much "stuff" was inside the door when I watched the new cable being fitted, the door even had its own ECU along with alarm system, heated mirror, moving mirror, window motor, door locking for drivers and/or other doors, under door lighting etc.
                          I kept the old door loom as it had a good range of different coloured wires which came in very handy when I made a new loom for a 70's motorcycle.
                          Phil
