Car oil leak, how do things like Wynn’s work?
Home Forums The Tea Room Car oil leak, how do things like Wynn’s work?
  • #712395
    Simon Robinson 4
      @simonrobinson4
      My diesel car has an oil leak from the timing chain cover. Ive had the leak off and on for over 5 years but not enough to cause a shortage of oil.  I’ve thought of removing the cover and resealing it but it’s in such a tight space. I understand there’s certain compounds like Wynn’s stop oil leak that you add to the oil to prevent leaks. What I don’t understand is why it takes over 200 miles of driving to work, why I’d doesn’t work sooner? Surely if it’s a sealant or some kind of adhesive the oil would break it down over 200 miles of sloshing about and prevent it working. I’m guessing with the heat of the engine it binds to plastic and silicone seals in the engine thus filling any leaks. Does it actually work or could I drain my oil and manually apply some kind of seal to the outside of the leak? Thanks in advance for any advice.
      Fulmen
        @fulmen
        I believe these treatments contain plasticizes for rubber. These can leech out of gaskets over time, reducing elasticity. But diffusion takes time, either way. So it makes sense that it will take some time to work.
        #712442
        JA
          @ja
          An additive manufacturer such as Wynns will not tell you what the magic ingredients are. Why should they? As long as they don’t damage the engine, OK.
          The possible magics ingredient are single cycle aromatics such as Benzene or Toluene. These will swell elastomars such as Nitrile or Viton O rings so improving their sealing. They are stable and will not react with the engine oil or any metals. The 200 miles comment is probably to allow plenty of time for the additive to reach the seal. However aromatics are carcinogenic or suspect carcinogens. I note that the Wynns website only shows one side of the can. The other side will have the instructions and a probable warning about using gloves and washing off any liquid splashes with water immediately.
          If so the tin would contain the aromatics with an oil as a dilutant and something to mask the characteristic smells of the aromatics used.
          I have never used such additives. However with an old engine I think they are worth a try. With a new engine you may be invalidating the warrenty.
          One question at the back of my mind, would ordinary engine oils contain small amounts of aromatics for the same reason.
          I hope this makes sense
          JA
          #712450
          peak4
            @peak4
            The data sheets are available from the manufacturer’s page HERE
            Bill
            #712455
              Unfortunately the Wynn’s Stop Oil Safety Data Sheet simply says the product doesn’t contain anything unfriendly, so it’s not possible to identify what’s in it.
              Unlikely to be a sealant or adhesive in the conventional sense.   Probably a chemical that’s liquid and soluble in oil that turns into a spongy solid after heating, and maybe contact with cold air.   The mechanism is probably:
              • Liquid added to oil in the engine dissolves
              • When the engine is started, the cold mixture starts to leak
              • After the engine has been running for some time, the stop-oil gets hot and converts into a solid.
              • The proportion that goes solid inside a small leak blocks it.   (Stop-Oil won’t fill big holes.)
              • Any solid left inside the engine oil is destroyed mechanically and by heat as the engine runs normally.   The solid isn’t hard enough to damage the bearings or strong enough to block oil ways or the filter.   Whatever it is mustn’t be too good!
              An old motoring trick is sealing leaking radiators by adding egg-white to the water.  Similar mechanism:  the egg-white solidifies when the water gets hot enough to cook it, and the resulting solid is man enough to seal a small leak.  Works moderately well because cooked egg-white is plastic so it can still plug gaps that open and close as the radiator heats and cools.   Any cooked egg left floating inside the water system is thoroughly mangled by the water pump and thermostat, so it doesn’t gum anything else up – we hope!
              As usual with ye olde folk remedies, egg-white has long been outperformed by commercial products developed and tested in a lab by chemists.  Although egg-white has the right sort of chemical and physical properties for the job, it decomposes and/or bacteria eat it. Not ideal.
              None of these products are permanent fixes, but in my youth I stretched the life of old bangers usefully with various potions.  They avoided an expensive repair on cars that were approaching the end.  (Back then I drove cars until they were downright unreliable, and spent many a weekend keeping them going.)  Most got scrapped when they developed multiple expensive age related faults: rust, worn clutch, pads or bearings, burning oil, perished rubber, faulty radio, dinged windscreen, unreliable battery, leaks, iffy synchromesh etc etc etc.   Beyond a certain point, not worth doing major repairs because everything else is in a poor state too.    Very easy to end up throwing good money after bad.  You can guess how I know!!!
              mark costello 1
                @markcostello1
                Oats run through a horse supposedly works also. Never tried it, I have no horse.
                #713013
                Fulmen
                  @fulmen
                  For once I get to disagree with SOD. No way there is anything that will form any sort of solids in there. Just imagine what that would do to the filter… Nor could it be simple aromatics. It’s the right idea, but solvents like benzene are simply too volatile to stay put, they will blow off first time the engine heats up.
                  #713037
                    The formula is obviously proprietary … but these words [from Bill’s linked page] give a good indication of the process:
                    Restores the elasticity of rubber and neoprene oil seal rings and O-rings.
                    Lubricates and maintains engine seals in good condition.
                    Dave Halford
                      @davehalford22513
                      This particular product is not like radiator leak sealer.
                      This stuff works by making neoprene seals swell. So what it will do is make your crank seals, front and back swell up, which is fine if they are knackered and leaking, if they are not they will wear faster. In some cases the valve stem seals will suffer as well. For use in end of life engines only.
                      The timing cover will be oblivious to all of this because the gasket is not neoprene.
