Capillary gaps required for silver soldering.
Home Forums Hints And Tips for model engineers Capillary gaps required for silver soldering.
Viewing 25 posts - 1 through 25 (of 29 total)
  • #457803
    Andrew Tinsley
      @andrewtinsley63637
      I have made half a dozen loco boilers from 3.5" gauge to 7.25" gauge. Also a series of smaller boilers for stationary engines.
      I have had virtually no problems with poor penetration of joints. I was idly thumbing through Tubal Cain's book on soldering and brazing, when I saw a chapter about setting up the job with the correct capillary gaps. Suddenly I had a guilty feeling, because I have never knowingly bothered about this aspect of silver soldering!
      I must have been very lucky. So to correct my bad ways, how does everyone else produce the ideal gap?
      Andrew.
      Andrew Tinsley
        @andrewtinsley63637
        #457808
        Tim Stevens
          @timstevens64731
          A simple experiment might help. Set up two small flat plates of your material upright on your soldering base so that one edge of each plate is touching the other, and there is a very small angle (1 degree) between the plates. Then apply your normal flux, heat the assemblage, and run your hard solder into the joint as you normally would. This will tell you how far into a narrow gap the solder will penetrate.
          My money is on 'all the way' but others seem to have alternative ideas.
          Regards, Tim
          #487603
          Roger Best
            @rogerbest89007
            I have that book and I remember the comments.
            Part of the warning was about gaps being too small on precision parts that were tight together. The other part was about using the solder as a filler for bad work. He is a demanding man. wink
            Its not so much about the ideal gap as the ideal solder for the quality of geometry. Will you need something runny to penetrate, or pasty to fill? The book tabulates loads of options but the message I took away was to ask a reputable supplier when I need some and to expect to have to buy a variety for any given model.
            #487614
            IanT
              @iant
              I'm certainly not an expert Andrew – but it is reasonable to assume that the solder requires some 'gap' to flow into – and also that too large a gap will not be bridged by the solder either. If there is no 'gap' then you may well get a fillet of solder at the 'top' of the joint but may not get good penetration actually into it. With boiler parts, I try for a sliding 'Goldilocks' fit – not too tight and not too loose but just right.
              For fabrications, I use Kozo Hiraoka's method of lightly centre-punching a few spots around the area to be brazed – effectively making miniature stand-offs. This seems to work very well for my needs and is a useful way of thinking of the size of gap required generally – e.g. some but not much.
              I also try to apply the heat in such a way that the solder is drawn into the joint where possible (it will flow towards the hottest area).
              So "some" gap and thoughtful application of the heat is the best I can advise others.
              IanT
              #487622
              pgk pgk
                @pgkpgk17461
                I'd guess that the main effect causing flow into a gap is surface tension (as in a meniscus and capillary tube?) I that's the case then I find it interesting that silver solder flows towards the hot end since with water the capillary pressure decreases with temperature…
                Presumably the flux applied into a joint before assembly also acts as a spacer?
                pgk
                #487627
                Andrew Tinsley
                  @andrewtinsley63637
                  Sorry for neglecting answers to my post. I have another two boilers to make so I shall be extra careful of my "gaps". It is odd that in all the boilers I have made, I have had only two very small leaks. I was quietly thinking that I was becoming an expert boiler maker. However Mr Walshaw took me down a peg or three!
                  I must have been taking note of clearances without really taking it on board, Otherwise I would not have got away with so few leaks. All the books on silver soldering / boilermaking make great play of the correct gaps and even quote figures. None of them give any tips on how one is to achieve this! Ian's mention of someone using ccowellsentre punch marks to define the gap is the first example I have heard of that is practical.
                  I put my success (luck!!!) down to using very large propane burners helped out with the odd oxy -acetylene torch. Like most people, my early mistake was not having the joint hot enough.
                  Thanks,
                  Andrew.
                  #487628
                  Andrew Tinsley
                    @andrewtinsley63637
                    Well I never, how did the Cowell's advert get in on the act???????
                    Andrew.
                    #487636
                    Bob Stevenson
                      @bobstevenson13909
                      It's curious how this keeps coming back on this site…..I think it must be factored by what you are soldering and what you desire as the ideal outcome…….. In makingn clock parts I try to get invisible joints that finish well with total penetration. as such i always try to get as tight a fit as possible and have never had any problem with silver solder faioing to 'run' when using enough heat and good flux. The danger with the 'gap method' is that molten silver solder is extremely 'runny' and percolates the tiniest tightest gaps by capillary action but is very bad at filling any larger gaps……
                      For clock parts I will stick with the methods that have served me well and always test that the solder has run thru to the other side of the join.in a fine line which is easy to polish out to invisibility.
                      #487644
                      pgk pgk
                        @pgkpgk17461
                        When using a centre puch to create a solder gap are you punching from outisde the joint surface to raise a dimplel through the material or punching within the (future) joint surfaces and depending on a raised crater edge?
                        Does anyone place scraps of silver solder foil near ,say, rivet points to prevent those being overtightened?
                        pgk
                        #487646
                        Brian H
                          @brianh50089
                          I believe that the normal method of providing a gap is to use a punch to make raised edges to the edges.
                          If using silver solder foil there is no need (or point) in using a centre punch to provide a gap, the foil has already done that.
                          #487679
                          Andrew Tinsley
                            @andrewtinsley63637
                            Thinking back to making boilers. I have always used what I consider to be a sliding fit for the components. I now am becoming more convinced that it is the flux itself that creates the gap on assembly
                            Bob you make an interesting point about tight fits. I am not too sure that some of the higher melting point solders are that runny, those with a high solid to liquidus range especially. However as long as you are well above the liquidus range, I suppose it doesn't matter.
                            The use of foils on assembly sounds a good idea and one that I have considered. However I have a nagging doubt about this method. Somewhere I remember reading that there is a snag . Maybe it was in Keith Hales book, wherever it was, I can no longer find this reference, perhaps someone on the forum can remember seeing it? Maybe it was the price of the foils, but i think it was a more fundamental problem.
                            Andrew.
                            #487695
                              I think the problem with foil is that if the two halves of the joint are not able to 'settle' it may be partially starved of solder.
                              I generally go with the centre punched dots.
                              I think the gap can be pretty small, as long as it's there.
                              Graham Meek
                                @grahammeek88282
                                I use a spring loaded centre punch to get consistent punch dot sizes and thus a consistent gap around the joint.
                                Gray,
                                #487720
                                Norman Billingham
                                  @normanbillingham91454
                                  The capillary gap can be very small indeed. There are published data for tensile strength of silver brazed copper joints with different gaps. The optimum gap is about 1.5 thou which gives a tensile strength of 0.9 GPa (135,000 psi). Smaller gaps give weaker joints by a very small amount, so it falls to about 0.7 GPa (100,000 psi) for a nominally gap-free fit. It’s thought that may be because it’s harder for the molten alloy to push flux out of a very small gap. However, the tensile strength is still 0.34 GPa (50,000 psi) at a gap of 20 thou. The ultimate tensile strength of annealed copper is about 0.2GPa (32,000 psi) so even with a 20 thou gap the joint will still be stronger than the metal. Bearing in mind that the diameter of a silver atom is about 350 pm (0.000014 thou), a gap of 1 thou will be enough space for more than 70,000 atoms of silver.
                                  #487733
                                  Andrew Tinsley
                                    @andrewtinsley63637
                                    Thanks Neil. Your comment on the use of foils rings a bell. I am sure that is the objection i have come across. I wonder where it was?
                                    #489076
                                    ron vale 3
                                      @ronvale3
                                      Cup alloys IIRC recommend a gap of 0.1mm
                                      #489085
                                      Hopper
                                        @hopper
                                        Luckily my tinsmithing is rough enough that the small gaps are inherent.
                                        Yet with any other piece of metal we are told we have to surface grind and scrape and lap and hone, rub with engineer's blue on a surface plate supported on three equilateral points set perfectly level to the nearest body of water and invoke magical incantations to get things to match each other closer than a thou or two.
                                        Edited By Hopper on 04/08/2020 06:28:59
                                        #489091
                                        Keith Hale
                                          @keithhale68713
                                          The joint gap is fundamental to the success of silver soldering.
                                          The laws of thermodynamics explain why silver solder flows to where it is hottest.
                                          The flux does not create the gap.
                                          This is explained in my book along with techniques on creating and maintaining gaps.
                                          There is 53 years experience of silver soldering between the book's covers.
                                          For more information, or to obtain a copy, send me a message.
                                          Keith
                                          Usual disclaimer does not apply!
                                          #489092
                                            Posted by CuP Alloys 1 on 04/08/2020 07:47:34:
                                            yes Nicely put
                                            Andrew Tinsley
                                              @andrewtinsley63637
                                              ,Hello Keith,
                                              I do indeed have the book! There has been lots of replies, but only a couple answered the question. To remind people, it was "How do you set up the correct gap for the alloy that you are using" I may well be wrong, but I don't think that even your book addresses the question.
                                              There are lots of references saying what the gap should be, but virtually nothing on how to achieve said gaps. Apart from some information in Alec Farmers book re brazing tubes in the inner firebox plate.
                                              For example I have seen people, including myself, riveting a structure to hold things together during brazing. The gap around the rivet must be close to zero, yet it still seems to solder well.
                                              I must have been very lucky , because I never gave gaps a thought in the past, unless it was subconsciously.and I have never had a major problem.
                                              Andrew.
                                              #489120
                                              Hopper
                                                @hopper
                                                Is it not like Loctite where roughing the surfaces with coarse emery paper provides myriad surface scratches a few thou deep for the liquid to flow through and form a grip?
                                                #489178
                                                Gary Wooding
                                                  @garywooding25363
                                                  I know that silver solder is a different alloy to sterling silver (92.5% pure silver) but the following anecdote might be of interest.
                                                  Some years ago I was given a small enamelling kiln which I thought might be useful for melting small amounts of sterling silver for casting small items.
                                                  To try it out I put a few grams of silver scrap into a dish type ceramic crucible and placed it in the kiln. The silver melted OK but it when cooled down I was surprised to discover that there was a thin film of silver underneath the crucible. It turned out that, unknown to me, there was a tiny, almost invisible, hair-line crack in the crucible.The molten silver had become sufficiently fluid to flow through the tiny gap.
                                                  #490620
                                                  ron vale 3
                                                    @ronvale3
                                                    Have a look at a gap of 0.01mm., a gnats todger wouldn'tfit through it but the solder will When i got all my bit laser cut byMalcolm i drew them with that gap..no problem whatsoever, plus if too tight you can tweak it a bit but you cannot narrow it
                                                    I was scared of soldering, so i practiced on some scrap..No problems now
                                                    #490639
                                                    Andrew Tinsley
                                                      @andrewtinsley63637
                                                      Hello Ron,
                                                      I don't have much problem silver soldering these days, as I have done a good number of boilers. Like most people replying, you state a gap measurement. Most manufacturers supply the gap range for the various grades of silver solder, so that isn't a problem.
                                                      The query I have, is how do you set the gap to 0.01mm ? Apart from the centre punch method, there have been no answers, I know the basics of the science behind the soldering. What I don't know is how do you jig the gaps?
                                                      Cheers,
                                                      Andrew.
