Cannot access homeworkshop.
Home Forums The Tea Room Cannot access homeworkshop.
  • #784774
    Graham Titman
      @grahamtitman81812
      Is anyone else having problems with the above site
      Ian Hewson
        @ianhewson99641
        Same here
        Ian
        #784787
          Just tried … There is obviously something amiss:
          jtablesession::Store Failed
          DB function failed with error number 145
          Table ‘./homework_adverts/jos_session’ is marked as crashed and should be repaired SQL=INSERT INTO jos_session ( session_id,time,username,gid,guest,client_id ) VALUES ( ‘9k1l5q61vav5s6j70dv7jpvv37′,’1740148452′,”,’0′,’1′,’0’ )
          Oldiron
            @oldiron
            Still down @17:26
            #784806
            Graham Titman
              @grahamtitman81812
              Thank you i thought it might be my old computer
              #784826
              Chris Gunn
                @chrisgunn36534
                This happens every few months, and then it comes back, so we just need to be patient I suppose.
                CG
                #784842
                bernard towers
                  @bernardtowers37738
                  It did this a few weeks back
                  #784849
                  Mark Rand
                    @markrand96270
                    Adam Stevenson (Sir John’s lad) has got a life to lead and gets bugger-all benefit for running the site!
