Cannon or Carronade?
Home Forums Help and Assistance! (Offered or Wanted) Cannon or Carronade?
  • #33493
    Martin King 2
      @martinking2
      Martin King 2
        @martinking2
        Hi All,
        A local clearance guy saved this for me at Shepton last Sunday, it is amazing what people chuck out!
        Is this a cannon or a carronade? Not sure of the difference?
        Beautifully made item, not fully bored sadly, (but it might be soon! devil)
        Cheers, Martin
        #440261
        Mick B1
          @mickb1
          Undoubtedly a carronade (after the Carron foundry where first made) from the slide carriage and the underslung trunnion.
          Carronades were shorter than standard guns, much lighter for the poundage of shot they threw, allowing a ship to carry a more formidable armament at short range than a similar-tonnage ship with guns.
          The lighter powder-charge also meant a lower velocity, which resulted in more lethal shower of splinters when the ball penetrated a thick wooden hull, therefore more – and more severe – casualties in the opposing crew.
          It eventually became apparent, though, that gun-armed ships could stand off out of carronade range and clobber the carronade ship without reply. Nevertheless they were still in use by the time of Trafalgar. The story is that HMS Victory opened the ball with a double-load from one of her bow carronades – a 68 lb roundshot and a keg of 500 musket balls shot through the stern transom of the French 'Bucentaure', allegedly IIRC causing morethan 400 casualties.
          That looks to be a real first-class model by a serious student of ships' weaponry.
          Edited By Mick B1 on 04/12/2019 17:58:30
          #440271
          Martin King 2
            @martinking2
            Mick, thanks so much for that useful info. This supposedly came from a small family museum that has closed down and was in a carton marked for the skip! That would have been a real shame! Hopefully there is some more stuff from the same place later this week, fingers crossed.
            Regards, Martin
            #440285
            old mart
              @oldmart
              I believe that the 68 pounder was the largest made, and sailors referred to the weapon as the smasher.
              #440474
              ega
                @ega
                Quite a bit about these in the Aubrey/Maturin novels.
                I believe the foundry also made domestic items – swords and ploughshares!
                #440490
                steamdave
                  @steamdave
                  Very nice model. It would be worth changing the plastic plaited rope for hemp 3 strand rope for added authenticity.
                  The Emerald Isle
                  #440502
                  Brian G
                    @briang
                    Posted by ega on 06/12/2019 11:58:34:
                    Apart from the Carronades, their most famous products were pillar boxes and phone boxes.
                    Brian G
                    #440509
                    ega
                      @ega
                      Brian G:
                      I have a Victorian hole-in-the-wall letterbox. Do you happen to know whether Carron were the sole makers? I would be glad to know the provenance of my letter box.
                      #440515
                      Marischal Ellis
                        @marischalellis28661
                        An interesting company. They made lots of things….in cast iron. They made compact cooking stoves (ranges) which went across the Prairie and out west with early settlers. Also made house stoves. Just thought this may be how ranges got their name. A company ended up making s/s sinks. A shadow of their former self, and long time taken over. The Lion Iron foundry may be a name for wall boxes.
                        Best wishes to all.
                        #440516
                        Marischal Ellis
                          Best wishes to all.
                          #440532
                          Brian H
                            @brianh50089
                            They also made Post Office letter boxes.
                            #440547
                            Brian G
                              @briang
                              Posted by ega on 06/12/2019 14:14:09:
                              Brian G:
                              There were several foundries making letter boxes for the post office, later boxes have the maker's name cast into the box below the door, although the only ones I have ever really noticed are Carron and W T Allen.
                              Brian G
                              #440579
                              Robin
                                @robin
                                Does anyone know, was Carron the only cannon maker in Falkirk back c1800?
                                If a ships cannon is marked FALKIRK 6Pdr, is it safe to assume it is by Carron?
                                #440597
                                Mick B1
                                  @mickb1
                                  Posted by Robin on 06/12/2019 23:08:51:
                                  Probably not. Google is your friend:-
                                  smiley
                                  #440608
                                  ega
                                    @ega
                                    Posted by Brian G on 06/12/2019 18:46:41:
                                    Brian G:
                                    Brian G
                                    Thank you. On checking I find that mine is by Allen; interestingly, there seems to be no mention of Carron in Robinson's "Old Letter Boxes".
                                    #440616
                                      Posted by Mick B1 on 07/12/2019 09:24:33:
                                      smiley
                                      +1! Scotland was a major producer of Iron, perhaps 25% of all UK production, and there were many firms making and using Iron there.
                                      Not all cast-iron back then was equally suitable for all purposes. Much depended on what was in the ore – unknown impurities – and tricks the Iron-founder knew that improved it. It happens that Scottish iron-ore produces a cast-iron well suited to cannon making, and – at a time when gun-making was hit and miss – guns made from Scottish cast-iron were reliable. Some English ores were also suitable, and both benefited from the Industrial Revolution. On average, British guns were safer than foreign ones, though the best foreign guns were as good as anything made in the UK.
                                      British guns sold like hot cakes, Carronades being popular on merchant ships because they can be fired by an unskilled team of four and are effective against pirates. Pirates can't blast victims at long range – they want cargo and ship intact, which means they have to get up close and personal with the gun. Most preferred not to risk it.
                                      Cast-iron improved significantly after 1841 due to advancing chemistry and metallurgy. The Artillery entry in Dr Ure's Dictionary of Arts, Manufactures and Mines quotes a US Government analysis of Cast Iron guns showing wide variances in density, tenacity, transverse strength, torsional strength, compressive strength, and hardness in the metal tested. The best cast-iron sampled was 5 times stronger than the worst. No surprise that guns often burst!
                                      Dr Ure mentions purity (achieved by better chemistry), melt control (achieved with air-blowers driven by a Watt Steam engine), and cooling methods as making significant improvements to British cast-iron between 1841 and 1851. Controlled heat and cooling are important because they effect crystallisation, understanding which demanded a microscope and scientists. British cast-iron guns made before 1841: average density 7.148, tenacity 23,638. Guns cast in 1851: average density 7.289, tenacity 37,774.
                                      Once their chemistry is understood, the special properties of local ore become less important. By tweaking the process, metal producers can accommodate a wide range of impurities and reliably churn out large quantities of metal to almost any specification.
                                      Top quality cast-iron didn't last long as a gun-metal. By 1851, gun makers were moving to more promising alternatives released by science and technology, first Wrought-Iron, then Cast Steel. The carronade was more-or-less obsolete by 1850, pushed aside by faster firing more powerful weapons. Wrought-iron was rejected fairly quickly because it's expensive to make and has a grain structure like wood – strong and weak depending on direction. Took about 30 years to get cast-steel consistently right in large volumes, but that's what we've used since.
                                      Artillery itself has a wobbly future. Guns are easily detected, for example by tracking the shell with radar, and they aren't easy to move quickly. Highly vulnerable to aircraft and guided missiles…
                                      Robin
                                        @robin
                                        Posted by SillyOldDuffer on 07/12/2019 10:56:14:
                                        Thanks for all that typing, I'm getting a crash course here and on Goggle or whatever it calls itself. The second spill off from Carron was the Falkirk Foundary in 1810 who signed themselves FALKIRK on pots
                                        So presumably this is by them and not Carron. There are quite a few of these floating about, I presume they were cast to order, but that would mean they didn't season the iron. I know so little, back to Goggling for me then.
                                        I actually thought iron was sorted out by Dud Dudley back in the 17th, but perhaps he only sorted it where he was. I have a reprint of his wonderful book where he prices the various irons and moans about the charcoal burners trashing his sea cole fired furnaces smiley
                                        Robin
                                        #440638
                                        Mike Woods 1
                                          @mikewoods1
                                          Martin,
                                          Beautiful looking model, you are lucky to have someone who spotted it for you. As far as boring out the barrel is concerned, might be better to leave as is, or just partially deepen it. There is a danger that you might wander into the minefield of firearms legislation. There was an interesting forum post on the subject here.
                                          Mick B1
                                            @mickb1
                                            Yes – a defensive battle of a merchant ship against pirates trying to board was a different matter from a fight between warships, and gave the Carronade a longer lease of life.
                                            I like the way Carron used to sell them as an integrated system, bundled with a full outfit of assorted ammunition for use against, hulls, rigging and personnel…
                                            surprise
                                            #440648
                                            Mick B1
                                              @mickb1
                                              Posted by Mike Woods 1 on 07/12/2019 12:41:00:
                                              Martin,
                                              I *think* you're OK so long as you don't drill a touch-hole through to the bore.
                                              Somewhere near where we used to live in Redditch, a bloke got some grief from police about a nicely-made model cannon he had. I believe the model was destroyed – but can't remember what happened to the owner.
                                              #440852
                                              Hollowpoint
                                                @hollowpoint
                                                I like that! 😎 I wouldn't bother boring it out. Leave it as original.
