My observations are it appears have a solid frame and girder forks so most probable pre war or at least pre 1950 I think, Had a short search and a BSA C10 c1939 seems a possibility, the timing cover looks similar and its a side valve engine [C10 was made for several years well into the 50's with tele forks] See a couple of links
May be, but carb may not be bolted directly to cylinder, may be a manifold or downdraft mounting. The puzzle is there appears to be a timing chest or it could be a mag dyno drive?? The no oil tank is a pointer to 2 stroke. The Classic Motorcycle – Richard Rosenthal expert on old motorcycles.
Michael, the OP image shows the engine fitted with an alloy cylinder head whereas the catalogue shows an iron head. The catalogue shows what appears to be a tool box on the off side and yet other images on the web show an oil tank for the dry sump lubrication on the offside where you would expect it to be located.
