Ordinary No-lead 'soft' solder has a rather higher melting point than old-fashioned soft solder (183C is the lowest for tin/lead, 227C for the cheapest tin+ 0.7% copper solder, more complex alloys can be lower (or higher)), with strength not much different. Some soft solders do contain a small % (less that 4%) of silver, but it is confusing to call them 'silver solders'. Soft solders rely on resin-based fluxes, or 'killed spirit' which is zinc chloride solution with some free hydrochloric acid. Some early bicycles were soft-soldered together (eg Dursley Pederson).
Silver solder (also called 'hard solder'
is quite a different set of alloys, requiring a different range of fluxes, usually borax based, and applied as a paste in water or alcohol, or dry powder. As well as a much higher melting point range, they are stronger, and tougher, so more suited to the higher pressures as well as temperatures. Many silver solders – which contain 50% silver or more – are silver-white in colour, some a bit nickel-pale-yellow.
Brazing involves a further range of brass, bronze, and similar alloys, with an even higher melting temperature. But the distinction between soft and hard solder is much clearer that between silver solder and braze. The answer to your question is 'yes, but don't expect worthwhile performance'.
Cheers, Tim
Edited By Tim Stevens on 28/04/2014 18:00:43
