Can I use brass?
Can I use brass?
  • #352095
    Adam Mara
      @adammara
      I have a plan Stationary Engine from the seventies, and am considering it for my first proper build. It specifies using Gunmetal for the Cylinder and steam box but I have suitable brass 'in stock' to do the job, is that OK? I will only be running it on compressed air.
      Adam Mara
        @adammara
        Advice for a beginner!
        #352102
          If you are just going to run it on the odd occasion for enjoyment without making it work under load brass will be fine.
          #352189
          mechman48
            @mechman48
            I will only be running it on compressed air…
            ​It will be fine if you're running it for short periods, just bear in mind to squirt a shot or two of cylinder oil / light hydraulic oil into the inlet, it will run fine,
            George.
            #352190
              Cylinder oil, even the light one can be a bit sticky when at room temperature so just a light oil would be best
              #352197
              Adam Mara
                @adammara
                Thanks for the advice everyone. I assume by a light oil 3 in 1 would do the job.
                As a matter of interest, I have a gallon tin of 3 in 1 oil, left over from when we closed our ironmongers shop down in 1993, price ? £3.60 !
