Posted by Breva on 23/06/2021 23:54:47:
Looking for a bit of advice please.
I have had to replace a dead battery in a Bosch GSB 12VE-2 professional battery drill. The original was a 12V 2,4Ah NiCd battery.
The closest replacement that I could find was a 12V 3Ah NiMH Vanon battery.
I have the original charger for the NiCd battery. (Bosch AL1450 DV 7.2V – 14.4V, 5A.)
Is there any reason that I should not use it to charge the new NiMH battery?
Will there be a big bang and magic smoke? No.
Will the battery recharge? Probably.
Is it a good idea? No. In the good old days batteries and chargers were both dimwitted so battery management was either done manually by professionals, or no-one bothered. Managed batteries have much longer lives and better performance than unmanaged batteries because the latter degrade. Big difference between:
- 20th century Lead Acid submarine batteries where engineers constantly controlled charge and discharge rates, monitored cell chemistry and checked the condition of the plates, and,
- Motorist charging a Lead Acid car-battery with a cheap charger. Car batteries are easily spoiled and there's a rich sub-culture of battery bodges to extend their lives a bit. Revived batteries are unreliable compared with batteries in good condition, OK to revive batteries yourself, but if you buy one you've been ripped off.
Modern batteries are likely to come with a built-in management system. The management system can be in the battery, in the charger, or both. What happens if the battery and charger are mismatched is anyone's guess. Expensive batteries and their chargers are often intelligent enough to refuse to charge unless they specifically recognise each other. Slightly less sophisticated systems rely on the battery telling the charger to maximise battery life by varying volts and current throughout the recharge cycle; the charge is optimised. Others simply limit charge time, rely on constant current, or have an overheating sensor. The customer doesn't know: he buys an appliance with a particular battery and a particular charger and is meant to replace them with compatible parts, not to mix and match.
Is it a bad idea? Maybe not. If the battery charges the result is unlikely to be outright failure. More likely, the battery won't quite be fully charged, and/or the number of recharge cycles it takes before clapping out will be much reduced: a battery that should last 1000 cycles, might only do 500 or less from the wrong charger. That may not matter!
However, if reliability is important, I'd try to find the right battery for the drill. Anything wrong with these?
