Posted by choochoo_baloo on 25/05/2020 23:28:23:
Posted by Dave Halford on 25/05/2020 21:02:07:
3 Cellulose is not synthetic or 1k as it tends to be called now. They don't like each other and will fight, synthetic looses every time.
Not sure what you're saying Dave (I am a novice!) – I shouldn't use this Selemix family on top of the hardened Upol 8?
I used the Selemix on cast iron and it's worked a dream. My main concern is how it'll take to an etch primer.
This is what you said in point 3
1 or 2 coats of my Selemix brush cellulose high build brush primer, to fill all marks in the rough casting. Datasheet description:
"fast drying synthetic primer with high filling and good anticorrosion properties.
It is intended to protect ferrous substrates."
Which is it synthetic or cellulose?
Cellulose will strip synthetic so the UPol may be at risk, your description does not match a current Selemix product
