I can't entirely agree with Neil. They do not 'work as well as.. ' conventional boilers. There are significant theoretical advantages in efficiency, time to developing steam and weight saving. The theoretical advantages were not all realised.
With less water in the boiler for a given external volume they get to steam quicker. With the majority of the outer case lined with fire brick, the average temperature of combustion is increased, leading to a better theoretical efficiency. The water tubes have a larger surface area to volume ratio, so in theory the smaller quantity of water can heat up quicker. It is possible to ensure that cooler water is heated up by cooler gasses – increasing the efficiency compared to a more conventional boiler. Due to a lower mass of water, the boiler power to weight ratio can be increased.
In practice, it it difficult to get all the listed advantages in a size as small as a train, and the boiler requires even more active management than a conventional boiler. The reduced weight of the loco can have implications for the tractive effort. In ships these boilers had massive weight savings – though the effect was more power for the same weight rather than reduced overall boiler weight.
Richard.
