can any one help me identify this model
Home Forums Introduce Yourself – New members start here! can any one help me identify this model
  • #645385
    Jeff Swinburn
      @jeffswinburn66016
      Hi have just got a steam model D 10 , all casings are bronze the disk wheel is steel the bed plate is ally and brass fabricated .
      the bore is 3/14in the stroke is 3/14in
      I can not find any information on the inter net , the only picture's I nan fined are the one I got of eBay ,and the same one on
      a sale room site . Stuart turner site said it is not one of there models img_20230516_142955248.jpg1000001714.jpgimg_20230516_143015272.jpg
      Edited By JasonB on 17/05/2023 10:19:09
      Jeff Swinburn
        @jeffswinburn66016
        it is not D10
        #645394
          I don't think there are any castings in that model, looks like it was scratch built and based around the Stuart D10 design
          #645500
          Jeff Swinburn
            @jeffswinburn66016
            Hi thanks for your reply , I did see a set of castings in the Stuart tuner catalog 1924 was called
            s v .slide valve vertical. all the castings where gun metal and the flywheel was steel.
            #645504
            Circlip
              @circlip
              Have a look at old 'Reeves' designs, Cylinder base castings look a bit like 'Warrior'
              Regards Ian.
              #645508
              noel shelley
                @noelshelley55608
                Not a D10 ! bore and stroke about right and the top cylinder covers look ok but the rest ? Looks a nice model. Noel
                #645511
                  It's not done with the Progress SV castings as they are only 1/2" bore, You can also see a joint line where the valve block is fitted to the curved cylinder and the shape of the A frames is arrived at by turning. Only thing SV and warrior about it is the use of square flanges at the top of the A frame to cylinder joint.
                  Not sure what base castings Ian can see by looks all bar stock to me, two rectangular rails onto a bit of plate
                  Edited By JasonB on 17/05/2023 10:22:19
                  #645513
                  Jeff Swinburn
                    @jeffswinburn66016
                    Hi thanks I have had a look at reeves Worrior it looks like its the same will take some measurements
                    thanks Ian
                    Will let you know later when get in work shop
                    thanks Jeff.
                    #645525
                    Circlip
                      @circlip
                      CYLINDER base Jason?
                      Regards Ian.
                      #645549
                        blush
                        #645553
                        Jeff Swinburn
                          @jeffswinburn66016
                          Hi I have had a little look at the reeves Worrior . a lot of the measurements are the same but the bed plate is
                          fabricated , I have made a new crank has the old one was beyond respire. the warrior had a 5/8 " stroke and 3/4
                          bore the new crank I made is 3/4 stroke and 3/4 bore . but it runs ok on very little air ,
                          I will up load video when I have done some more bits to it .
                          thanks Jeff
                          #645607
                          Roderick Jenkins
                            @roderickjenkins93242
                            Those standards are pretty distinctive
                            Jeff Swinburn
                              @jeffswinburn66016
                              Hi I think the model is made from reeves castings with a scratch built bed plate ,
                              thank you all for your help on identifying the model , I can now get on with making it look better
                              thanks again Jeff
