Posted by paul tomlinson on 29/04/2013 18:26:18: Have you seen the cnc lathes (Sieg) imported by Axminster, they seem very affordable and might be my next purchase if I can get my head around this simple Syil lathe.
Thanks for all your advice, Paul
Paul,
Don't bother. These are called KC4S and KC6S, the S on the end defines a Sieg controller which is a very basic controller made for the home Chinese market but it has an English screen.
There is no support for these outside of China nd they are very clunky.
Add to this the KC4 is powered by a 500W brushless DC motor but it's manual based machine, the C4 has a 1000W brushless fitted making this an underpowered pig.
The KC6 has a very high cross slide which means that the largest piece of material it can spin over the slide is about 50mm and the cross slide also has very short travels.
Basically neither of these two machins have had much thought put into them, probably why no one else carries them ?
Not a sour grapes post as I have a KC4 here, it's now much modified but still has limitations.
Lathes are the Cinderella of the CNC world, people think they are just a 2 axis mill wjhen in fact they are far more complex.
